I have Magix Movie Edit and I also use ImgBurn. I have .avi files of my favorite tv show. I'd like to make a compilation video of all my favorite scenes and add my own music to it. I need some help please. Is there a software out there that would be best for this? I am a noob at this video stuff and all the google stuff lead me here. Any tips or advice? thanks
The odds of a self-confessed newbie pulling off a compilation is pretty slim....a compilation from multiple "AVI" sources is going to be VERY nerve-wracking. If you are replacing the the audio with your own then it won't be so bad. Cutting most flavors of "AVI" and joining them results in serious audio sync issues if not done correctly(IE....cutting on key frames)....and key frames are almost never where you want/need them. Cutting outside of a key frame requires re-encoding of the video.....degrading the quality of the AVI even more.
Depending on the format of the AVI, I would try VirtualDub with the 'smart render' function on. Then you may be able to make the cuts where you want and just have it re-encode at the cuts and hopefully keep it all in sync. You can replace/modify the audio with VD or use the freeware audio editor Audacity to smooth it up later. You will likely have to do some audio adjustments for level, etc. There are guides for both programs listed on their tool pages. <<<<<
Weird Compilation Errors
By theWallflower in forum Authoring (DVD)Replies: 8Last Post: 8th Apr 2010, 07:00 -
When Ripping Compilation CD's...
By Nitro89 in forum Off topicReplies: 3Last Post: 1st Nov 2009, 08:48 -
Differing volume levels on compilation video DVD
By mr_tinka in forum Newbie / General discussionsReplies: 15Last Post: 4th Sep 2009, 22:12 -
DVD compilation.
By Benhermies in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2008, 11:46 -
Putting text over a video (making a compilation RATM DVD)
By Salva Veritate in forum EditingReplies: 4Last Post: 1st Sep 2007, 13:52
