From camcorder at 17 or 24 Mbps, 1920 x 1080, 29.97 fps.
After editing, what bit rate should I use to encode? Some suggested to use a bitrate slightly higher than source, (e.g. 18 Mbps for 17 Mbps source). Does this make sense?
Thanks!
	Yep. If size is not an issue then use highest possible bitrate when you reencode for best quality. Or use constant quality encoding mode.
  cleaning video, does this make any sense?By deadrats in forum Video ConversionReplies: 44Last Post: 9th Dec 2009, 22:03
  Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p fileBy SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57
  Higher Bitrate = Higher Quality?By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 22:33
  Does this convert formular make sense?By helenw in forum Video ConversionReplies: 0Last Post: 26th Oct 2009, 18:04
  From Letterbox to Anamorphic. Does it make any sense?By Instant Martian in forum DVD RippingReplies: 4Last Post: 9th Aug 2009, 13:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
