Hi,
I am a registered user of VOB2MPG and I am using it to extract TV series from DVD onto my HTPC. On a single DVD, there may be 5 or 6 episodes. I am using XBMC and it likes the names of the episodes in this format: ShowName.SxxEyy where xx is the series number and yy is the episide (eg Hogan's Heroes.S01E13)
Could you put in an option to allow the autoincrementing number for the filename?
Here's how I think it could work - get the user to enter the filename with a % where the number needs to be, also get them to enter a starting value and how many digits are needed. So for the above example, the values would be:
Filename: Hogan's Heroes.S01E%
Starting number: 12
How many digits: 2
This would then create these output files: Hogan's Heroes.S01E12.mpg, Hogan's Heroes.S01E13.mpg, Hogan's Heroes.S01E14.mpg if there were 3 checked titles.
Thanks in advance,
Regards,
Doug
