I am trying to change the bit rate on an mkv file. I am trying to play this via usb on an LG LCD but video seems to stall, break up. It seems that other files work when the bit rate is at Mbps range and this is only at Kbps. Also the Format profile in others are at High Profile 4.1 and the ReFrames are at 5 or 4. BTW the audio here is 2 channel that was converted from 6 channel. What settings should I use or should I encode this with MPEG-4 instead of H.264? How do I prevent the app from shutting down windows in one minute after I close the activity window. TIA.
Well I was able to render the mkv file after 20+ hours into one that did play well on the LCD. The only problem was that it had no audio and the aspect ratio wasn't preserved. I am attempting this again hopefully preserving the aspect ratio and deleting one of the audio tracks (aac) while keeping the other (ac3) which plays with the LCD. This process is taking 30+ plus hours, is that amount of time correct? Is there other software that can perform this faster. Perhaps SUPER?
[ASK] Handbrake 0.9.5
By czgirb in forum Video ConversionReplies: 17Last Post: 28th Jan 2012, 16:29 -
Handbrake cropping too much
By ryangarfield in forum Blu-ray RippingReplies: 2Last Post: 14th Jun 2011, 16:42 -
Handbrake 0.9.5: Best settings for me?
By Pokelus in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2011, 15:04 -
Handbrake
By Bazza-61 in forum Blu-ray RippingReplies: 4Last Post: 19th Oct 2010, 06:16 -
Handbrake subtitles off
By perdomot in forum SubtitleReplies: 2Last Post: 17th Jun 2010, 23:09
