Hi friends,
I want to hardcore subtitles to certain frames where different language other than English is used.so i cut these particular portion from these movies and hard cored subtitles using Xvid4psp.the problem is when i appended these edited portions to original clip the edited portion is not playing or it gets blurry.i don't want to re-encode and merge them as a single clip as it would degrade the video quality.plz tell me if it is possible to merge and play the movie as normal using any video tools or is there no way but to re-encode them.any help will be greatly appreciated
Thanks in advance
Results 1 to 29 of 29
If you can get the subtitles in a text format, such as SRT or ASS, you can just delete all the ones you don't want and save it as a new subtitle file.
Use, eg, Subtitle Workshop to edit SRT subs.
You can add your new sub to the MKV, in addition to or instead of the original, maybe you can make it the default. No hardcoding subs or re-encoding of video required. -
thanks alanhk for Ur reply!!but i want to hardcore subtitles.so i think there is no way that i can merge the hard-coded portions to original clip and see them as normal video
I doubt it.
You haven't said what kind of video or how you play it, but every software player I know supports soft subtitles.
You can use MKVmerge to add or replace subs in an MKV, for instance.
I've used MKVextract to get soft subs out of an MKV to edit.Last edited by AlanHK; 26th Dec 2010 at 03:54.
I will provide you with samples that way you will understand my problem better
Video 1-Subtitle Hard cored videoLast edited by kurian; 28th Dec 2010 at 12:12.
Video 2- Sample of original video to which hard coded video is to be appended
Video 3- Resulted video file when appended video 1 and video 2(mkvmerge) which gets blurred or unwatchable at the portion where video 2 beginsLast edited by kurian; 28th Dec 2010 at 12:46.
is there any way to merge video 1 and video 2 and play them as normal without re-encoding it which will degrade the quality of entire movie.plz suggest any methods to achieve this.i have been trying to do this for weeks.any help will be appreciated
at least tell me if it's possible or not.is it because the bit rate of hard cored video is different from original video I'm not able to play it as a Normal file.plz reply
I don't know exactly what it is but there's something different enough about the two videos that they can't just be appended -- at least with MMG. Video 1 is encoded with x264 with profile High@L4.0. Video 2 is encoded with an unknown encoder with profile High@L4.1. Otherwise they seem to be quite similar.
I'd try reencoding Video 2 with x264.
<edit>
I tried reencoding Video 2 and appending that with the original Video 1 -- same problem. After reencoding video 1, then appending the reencoded Video 2 to the reencoded Video 1 the result played properly.
</edit>Last edited by jagabo; 29th Dec 2010 at 10:52.
thanks jagobo for ur reply.video 2 is a sample from the original clip to which subtitle hard corded video is to be added so i would have to re-encode the entire clip .it would be better to re-encode the subtitle hard coded clip to High@4.1.and then i will tell you the results
If you encode both videos with the same encoder and similar settings, yet, it's possible.
Using Avisynth always involves re-encoding.
You haven't explained why you can't use soft subs, which would be the simplest solution.
Your method should work in theory, but there is something about your video1 which makes it difficult to match its properties when encoding your video2. For that reason (and only that reason), you need to reencode video1 too. -
Merging mkv failed
By skinney6 in forum EditingReplies: 3Last Post: 10th Mar 2012, 10:05 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Problem merging 2 MKV's
By nutman in forum Video ConversionReplies: 3Last Post: 7th Dec 2010, 09:31 -
Subtitles not showing after merging with MKV
By CrimsonCobra in forum SubtitleReplies: 0Last Post: 10th Aug 2010, 21:43 -
MKV merging help
By snadge in forum Video ConversionReplies: 0Last Post: 25th Oct 2009, 13:19
