Hi. I've been trying out MeGUI and xmediarecode and have decided to use xmediarecode (ease of use, fast, excellent results). Even though the Volume Correction is set at 100% (which I take to mean the volume of the new file will be the same as that of the original), the volume of the new file is quite a bit lower.
Can anyone suggest a reason why that might be? Thanks for any suggestions.
If you converted to AC3 you may just need to turn up the audio gain on your AC3 decoder.
Thanks jagabo. However, I just discovered a button on xmediarecode called 'copy audio' which sorts the problem.
How to lower the FPS for a MKV file?
By sldvd in forum EditingReplies: 6Last Post: 1st Jan 2010, 10:30 -
Lower volume with Zoom Player
By genegold in forum AudioReplies: 2Last Post: 5th Aug 2009, 01:48 -
Lower volume of mpeg file
By pslates in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 14:57 -
Sony Vegas 9.0 Platinum how do I raise and lower the volume?
By LoveMyslf in forum EditingReplies: 1Last Post: 7th Nov 2008, 13:28 -
lower file size for a capture
By matneaves in forum Video ConversionReplies: 6Last Post: 1st Sep 2007, 12:34
