So I was on my dell Latitude D630 laptop today and I was about to play Starcraft 2, suddenly the screen flashed a couple times and now my entire screen is highlighted in neon pink and green colors. It even does on the start up screen for windows. Totally neon green. It's really awful and I don't know whats causing it. Video card? Please help!!!
	Googling revealed that several other users have had similar problems.
 It could be the video card, but more likely it is the wiring between the card/motherboard and the screen. If so, this video cable may have to be renewed.
 For a skilled technician, this shouldn't be a difficult procedure.
	I agree -- there is a high likelihood that it is the cable from the motherboard to the screen.
 However, try removing the battery from the unit (while it is turned off and not on the wall charger) for about 5 minutes. There is a small chance that the video system crashed and hasn't completely recovered (even with a restart). Removing the battery removes any possible power source from the machine and waiting 5 minutes allows capacitors to fully discharge thus de-powering anything that their charge might be running.
 Unlikely, but worth 5 minutes to try...
	Make certain you haven't picked up something like "Antivirus 2011". I fixed one machine that the screen had turned mostly black. ;/ l ,[____], Its a Jeep thing,
 l---L---o||||||o- you wouldn't understand.
 (.)_) (.)_)-----)_) "Only In A Jeep"
  Possible to use laptop screen as external screen?By WinSpecToR in forum ComputerReplies: 9Last Post: 31st Dec 2011, 11:29
  Laptop is showing nothing on screen.By chewie8008 in forum ComputerReplies: 4Last Post: 26th Jun 2011, 23:56
  Subtitle problem that fills screen with pinkBy oldjoe911 in forum SubtitleReplies: 2Last Post: 27th Oct 2008, 14:54
  When certain subs appear, the whole screen goes pinkBy oldjoe911 in forum SubtitleReplies: 1Last Post: 9th Sep 2008, 18:14
  YpbPr on Hdtv only shows pink screen.By tiagirl in forum Newbie / General discussionsReplies: 4Last Post: 14th Apr 2008, 13:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
