This nifty little program was given to me by someone long gone that was helping me troubleshoot a video problem. Anyways ...
Is there information provided in one of the GSpot fields that will inform me of the video's resolution (which I am assuming means display/picture quality) without viewing? Say, I have multiple choices of the same movie. Many times the author provides a lot of specifications of the video. Through trial & error I have learned that file size and frame size do not have much to do with video quality. Also, if GSpot is not the proper tool to address this, please let me know of another or if there is no such tool that can make such a determination.
-thnx
Results 1 to 12 of 12
If you know the source spec, it is easier to predict "picture quality" through various codec recode settings but source quality dominates.
http://www.kiva.org/about -
ok folks. responses thus far have the populace here voting for my previously stated "no such tool for this exists" option. I was hoping that video quality could be thus analyzed from a 'numbers' point-of-view. You know, like how one can 'know' that an mp3 file will be of higher sounding quality the higher a 'certain' spec. number is. hmmmm ...?
GSpot reports a "Quality Factor" (labeled Qf in the UI) -- the bits per pixel of the video. That's a rough guide to quality. But again, different movies, codecs, settings, and captures can cause very wide variations in compressibility. So just because you find one video has a higher Qf than another doesn't mean it's better visually. Really, the only way to know for sure is to look at the videos yourself.
If you want to see some extreme examples, look at the videos in this post:
https://forum.videohelp.com/threads/295672-A-problem-for-video-experts?p=1811057&viewfu...=1#post1811057
How relaiable is gspot?
By charyuop in forum Authoring (DVD)Replies: 5Last Post: 11th Feb 2012, 14:19 -
Is GSpot buggy?
By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 6th Oct 2011, 16:13 -
Question about incorrect DVD information given by Gspot
By jimdagys in forum DVD RippingReplies: 2Last Post: 9th Dec 2009, 00:24 -
Gspot question
By pinetop in forum Newbie / General discussionsReplies: 1Last Post: 2nd Oct 2008, 09:27 -
Help with Gspot Results
By Dawter in forum Newbie / General discussionsReplies: 1Last Post: 12th May 2007, 07:01
