I tried smart ripper and can not get the subtitles to work. and Flask I have no idea on how to do it and help thank you
i wuz told that smart ripper only ripps the vob files aint got a thing to do with subs! but im currently in the same situation as you. i cant figure out how to get the subs off all my anime dvds! and i got a bunch of em! i could ripp em with da english language but who wants a dubbed anime flick!
i know i dont! so far ive tried using DVDx but i could nt get the dang thing to sub all the episodes on my dvds! in fact it only seemed to subtitle and ripp like the first 2 1/2 minutes of the first chapter! i cant figure it out! plus the quality sucked! when there wuz more motion involved in the video i got horizontal scan lines across the screen!
and flaskmpeg, well i cant even get that to work!
oh well, if someone knows the answer for easy subtitling, please help!
alohaz! -
i know how to encode anime with sub using avisynth and its subtitle plugin but it not easy. Need a little bit of work. Use Subrip to rip the subtitle off anime dvd
You have to rip the .IFO files along with your .VOB files from the DVD. Convert your .VOBs using DVD2AVI and VFAPI - make sure to pick the approriate audio track in DVD2AVI, and Save as a Project, not as an .avi file. Then in VirtualDub, you use the VobSub plugin to read the .IFO files, and it puts the subs in properly. Then you can either save as a DiVx file, or frameserve to TMPGEnc to encode into mpg.
Smart ripper will rip all of the files off of a DVD, you just have to set it up to do it properly.
Where to download free srt subtitles (Mostly for anime)
By lelouch283 in forum SubtitleReplies: 3Last Post: 19th Oct 2010, 06:53 -
how to put subtitles under the vedio !
By ary190ary in forum SubtitleReplies: 4Last Post: 31st May 2010, 17:48 -
streaming anime no subtitles showing half the time/off screen
By thewhiteboy23 in forum Newbie / General discussionsReplies: 17Last Post: 18th Oct 2009, 12:46 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 15:31 -
How to put subtitles to a mkv file
By donpato in forum SubtitleReplies: 2Last Post: 6th Apr 2008, 16:17
