I have 500gb Seagate HD that died on me. Using sata cable, i cant see it at all but i can using usb. I cant see it in My Computer but I can in Computer management. It is not initialized and unallocated and when I try to initialize the disk, it gives me Data error (cyclic redundancy check).
I used the program GetDataBack to search through the sectors for 3 days straight and it is only 16% done. So far nothing is found and I keep getting errors for the sectors.
So is there a way (software) to permanently remove the data without physically damaging the drive so i can get warranty?
Results 1 to 11 of 11
they're cheap. my preferred method is a sledgehammer. especially helpful for seagate, maxtor and hatachi drives, as you need to use it frequently.
small hammer works just as well.... just hit more often... to ensure full removal use a torch & melt it)
You can try a program called Zero Assumption Recovery
http://www.z-a-recovery.com/
This worked for me when one of my drives went awol. But if you have already run some utilities on it - or even tried to format it - then I doubt that even this will work. -
does the freezing method work? if i leave it in there longer, maybe the moisture can destory more of the drive but not visible so i can get the warranty?
Freezing was thought up to get that last bit of data off a drive.
If you want to erase the thing: treat it like a VHS and magnetically wipe the thing.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Recover Semi Dead Hard Drive
By imdaman in forum ComputerReplies: 7Last Post: 11th Jan 2011, 10:30 -
WD Hard drive dead after 6 month break?!?!?!
By navi310 in forum ComputerReplies: 8Last Post: 10th Jun 2008, 21:52 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58 -
External Hard Drive - Dead! - Need advice
By pooty13901 in forum ComputerReplies: 7Last Post: 20th Sep 2007, 18:07 -
How to recover data from a dead hard drive?
By Captain Satellite in forum ComputerReplies: 25Last Post: 28th Jul 2007, 16:12
