hi,
I just bought a Sony VCL-HA07A conversion lens for my Sony Handycam DCR-SR45. I didn't open the box for the conversion lens yet cause I don't know if it will fit or even know how it's going to install. Does anyone know if this conversion lens will fit this video camera?
thx
Camcorders that accept filters/conversion lens have threaded rings of specified diameter. Most times this is labeled on the lens itself or in the manual. The conversion lens must match the diameter spec.
The DCR-SR45 has a "filter diameter of 30mm. The lens needs to match.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10151&catalo...specificationsRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
EdDV,
Thanks for the quick reply. The box actually says it will fit 25, 30 and 37mm lenses so I opened it up and the conversion was a cinch.
RSpades
Lens Question
By budwzr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 29Last Post: 6th Aug 2011, 11:01 -
Lens Help?
By MurbeckJackson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 30th Jan 2011, 16:41 -
Camera or Lens?
By andy33 in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2010, 20:55 -
Fisheye Lens
By JakkOne in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Dec 2008, 01:10 -
Cleaning the lens?
By Digiface in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Sep 2008, 10:27
