can this be done even the files are not exactly the same like making multiple short movies. I have dvd flick I use but never tried multiple files or is there a better program.
Depends on what you want to get out of it.
DVD Flick can do what you want. If they are separate titles then just load each into it's own track and be done with. If they are parts of a single title, load the first part as a track, open the track's properties and add the rest, check the order, and away you go.
AVS2DVD does a great job with multiple titles, but cannot join multiple files into a single title (I believe - I may be wrong with newer versions)Read my blog here.
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
Problems converting Multiple .avi files w/ subtitles to DVD
By bwanis in forum MacReplies: 2Last Post: 30th Nov 2007, 13:23 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 14:37
