I see multiple ones offered on amazon and I'm not sure which is best.
http://www.amazon.com/Canopus-77010150100-ADVC110-Converter/dp/B00030ATTO/ref=wl_it_dp...=3I07YG19ITNVR
http://www.amazon.com/Canopus-77010138100-ADVC-55-Converter-External/dp/B0006ZSQL4/ref...=3I07YG19ITNVR
Yes, I know DV capture is not as good as uncompressed. I have a PCI capture card but have not gotten it to work properly. I already have a different DV capture box from Pyro ADS but it drops frames like crazy. Meanwhile my dvd recorder handles just about all video with no problem. (sometimes the Pyro drops when the video is perfectly clean)
So basically, at this point I just want to have a better DV capture box (that captures rough video as well as a dvd recorder) and I have heard many times that the Canopus brand is the best for this aspect. So what version is recommended?
I've heard there is an advanced one with all sorts of video enhancement settings but they can't always be turned off. And careless noise removal can cause bad smearing and lose detail. Plus I can correct the color in vegas anyways?
Also, is it true what someone on amazon wrote about the Canopus box blocking copy protected stuff such as vhs movies with Macrovision?
Last thing first, the current ADVC models respect Macrovision. Older ADVC-100 models can be set to ignore Macrovision.
The ADVC-55 is a one way analog to DV format converter.
The ADVC-110 is a two way device that can also convert DV to analog composite or S-Video. DV output is very useful for monitoring an NLE timeline to a TV or broadcast CRT monitor giving a true indication of video quality. Computer display cards do not allow accurate monitoring without complex calibration. DV output is also useful for system calibration. You can adjust your monitor to accurate DV test signals on the NLE timeline. In adition, the ADVC-110 outputs an accurate color bar internally.
The ADVC-300 has all the features of the 110 plus a one line TBC, simple noise reduction and proc amp controls.
I use an ADVC-100. It has been stable under all conditions so far.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
My old ADVC-100 easily ignored macrovision settings when I moved VHS content to DVD.
As a side note, had no dropped frames using WinDV and audio always stayed in sync. -
Get the 100 if you can still find it.
I bought the 110 as a backup to my 100, but found it has flawed macrovision detection that gives the light and dark effect for older self recorded tapes that don't have macrovision. I ended up returning it.
I recommend the 55 over the 110 as it did not have the contrast problem with older tapes. If you buy the 55 make sure you have a powered firewire port, otherwise you also need to buy the AC adaptor.Last edited by Vidd; 24th Dec 2010 at 12:19.
I'd get this one: http://www.amazon.com/gp/product/B0006ZSQL4?ie=UTF8&tag=thdifa-20&linkCode=as2&camp=17...SIN=B0006ZSQL4
No reason for the higher models if you want DV input.
And use WinDV.Want my help? Ask here! (not via PM!)
Only the early model ADVC-100 models had the MV override feature. Around 2005 the feature was deleted. Shop carefully.
I have to use a power source for the existing Pyro device. If I get the 55, will I need to buy a new power adapter or should the existing one I already have work. Or does it come with one?
Interestingly, I got my pyro box in 2003 and I have recorded off the Star Wars Phantom Menace and Empire Strikes unaltered dvd with no problems. I guess I already have something that doesn't detect copy protection. The vast majority of tapes I want to focus on converting were recorded with a video camera (mostly Hi8) anyways.
NOTE: A Canopus DV box does not replace a TBC!
By lordsmurf in forum Capturing and VCRReplies: 58Last Post: 20th Nov 2018, 15:47 -
How to capture cable box output to PC
By mickelsen in forum Capturing and VCRReplies: 7Last Post: 1st Jan 2012, 18:13 -
Best capture box?
By timeforchips in forum Video Streaming DownloadingReplies: 1Last Post: 10th Sep 2009, 17:00 -
Anybody Need a Canopus ADVC110 to Capture With?
By Endzone in forum Capturing and VCRReplies: 2Last Post: 8th Jan 2009, 16:09 -
Today only, Pinnacle hardware DivX capture box.
By olyteddy in forum Capturing and VCRReplies: 0Last Post: 7th Nov 2008, 09:56
