Try DVD Fab Video Downloader and rip Netflix video! Or Try DVD Fab and copy Blu-rays! or rip iTunes movies!
  1. Hi;
    Can I play MKV files with the Samsung BD-C6900? Is there a guide?
    Thanks.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by esabet View Post
    Hi;
    Thanks.
    Check the manual for file restrictions. Let us know what it says.
    I noticed the Samsung BD-C5500C box had a "MKV HD" logo. I'm unfamiliar with how that is defined.
    http://www.kiva.org/about
  3. Banned
    Freedonia
    MKV can literally hold any possible video and audio codec so we can only say that you can play some, most or perhaps even all of your MKV files depending on how they were made. The documentation with the player should state what is and is not supported inside an MKV container, assuming that your player does claim to support MKV files.
  4. Thank you for the explanations. I figured it out and so far so good!
