Hey I got a problem
I am using txt2sub to create subtitles in sub/idx type which is the format I can use.
The problem is that when I finish subtitles they are not well displayed, looks like the interior of subs are transparent which make them look horrible and almost unreadable. (I tested both on pc and on HD player)
Any idea what the problem may be?
Is there another application to convert srt to sub/idx ???
Nice, I used SubtitleCreator to make them and they look alright.
Thanks, problem solved
.SRT (text) to .SUB/.IDX (image) subs
By Sheavi in forum SubtitleReplies: 7Last Post: 29th Dec 2009, 04:42 -
use AviSynth script to add graphic idx/sub subs in DVD Flick?
By MilesAhead in forum SubtitleReplies: 7Last Post: 17th Dec 2009, 13:24 -
How to add permanent subs inside a semi-transparent box?
By majin_buu in forum SubtitleReplies: 5Last Post: 9th May 2009, 12:43 -
Converting sub and idx subs into srt
By peyem in forum SubtitleReplies: 1Last Post: 4th Apr 2008, 19:23
