I use DVD Movie Factory 3. Yes, i should upgrade to their latest, and i will do that in due time. In the meantime, DVDMF3 has been working pretty good, until the last few nights. I usually get some pretty dang good captures to go from VHS to DVD. For some reason, the latest movie i've tried is not working out. The movie is pretty nice looking. VERY good quality tape. Has hardly ever been played, from the way it looks. Does field order have anything to do with the capturing? I am just trying to go through some troubleshooting. The capturing is very jerky. Trying to find out if it has to do with field order, and what it should be set to. I also should defrag the drive i am using. I will do that right now.
Please advise. Thank you!
MPEG2 can accommodate top field first and bottom field first equally adeptly. If you suspect you have a field parity problem with a sequence, there's an few ways to handle it. One way is to simply run the MPEG2 video through something like project-x and flip the field order then see how it plays on a standard TV set via a standard DVD player. No recoding required.
http://www.kiva.org/about -
Analog interlaced video doesn't have a "field order". It's just an alternating sequence of top and bottom fields. It's only when those fields are captured and stored as frames (two fields per frame) that you have a field order. The capture device can start with a top field then add the next bottom field to fill a frame, or vice versa. So the player has to know which of the two fields in each frame was captured first in order to play them back in the right order. The field order is determined by the capture device. I've never seen a capture device that let you specify which field order to capture in.
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Problem with field order on captured video
By brassplyer in forum EditingReplies: 8Last Post: 3rd Apr 2009, 07:06 -
Swapping field order in progressive video.
By jmail524 in forum Video ConversionReplies: 1Last Post: 3rd Aug 2008, 13:53 -
> Ulead VS11 Broken MPEG 2 Field order <
By Dark Alpha in forum EditingReplies: 8Last Post: 24th Jun 2008, 09:29 -
quickly fix reversed field order w/o re-rendering MPEG-2?
By miamicanes in forum Video ConversionReplies: 2Last Post: 14th Sep 2007, 22:19
