I have a Philips DVP5960, with the USB1.1 on it. My old roommate had an external HD that allowed him to play .avi video on the player when connected via usb. I just purchased a Hitachi X500 external HD, put some .avi files on it, and hooked it up, but no dice. Any advice as to what I can do to make this operation successful? Firmware? Or should I look at a different eternal HD? Any help would be much appreciated - usually I'm fairly electronics-savvy, but this is eating at my brainpan with a violent fervor.
Results 1 to 13 of 13
http://www.kiva.org/about -
Is it a single active partition? I don't remember for sure, but it may not work with extended partitions. Try using Swiss Knife to format.
http://download.cnet.com/CompuApps-SwissKnife-V3/3000-2248_4-10070864.html -
Mac OSX will allow you to set a FAT32 primary partition with a second HFS partion. Problem is pure FAT32 only allows 30GB maximum partition size.
It's Windows 2000/XP/Vista/7's format utility that's limited to 32 GB. Win98 can create up to 128 GB FAT32 partitions. SwissKnife can go higher -- at least up to 2TB. Larger FAT32 partitions may not work as boot drives and some other device may have problems with them. I don't know what the Philips 5960's limits are.
One possible issue - even if you get the disk format right on the hard drive, some DVD players require that some external hard drives be powered to play them from a USB drive. If your drive does not come with its own power source you may need that to make it work. I can't guarantee that this is your problem, but I have heard of this being the issue.
My Philips 5992 has power on the USB port (even with the unit turned off) but it may not be enough to power an external drive. I use it to power a LED lamp.
That's a good point. Philips players do provide some power on the USB port but not as much as a PC. So many USB powered hard drives will not work without external power.
The 90/92 models have enough power for any external based on the 2.5" drive,but not the 60 and 82 models.did u test it with a flash drive?
Philips DVP5960 and USB
By lets in forum DVD & Blu-ray PlayersReplies: 715Last Post: 10th Jun 2012, 10:03 -
philips dvp5960
By tonie in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 14:58 -
Philips DVP5960 or 5982?
By siskiou in forum DVD & Blu-ray PlayersReplies: 11Last Post: 20th Apr 2008, 21:28 -
Philips DVP5960 - firmware "upgrade" to fix jerky video is a &quo
By tzikeh in forum DVD & Blu-ray PlayersReplies: 13Last Post: 18th Nov 2007, 14:47 -
Philips DVP5960 Help
By clubfoot in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Sep 2007, 05:39
