    Dec 2010
    USA
    I'm using V2.
    I use a small Inner Diameter setting. How can I make that a default Print setting as I always get the dreaded warning "I'm useing a small diemeter setting" and have to click "Ok" every time I go to print. I should not have to jump though that hoop every time I go to print.
    If this is not an option... is there a software that you recomend?
    Thanks Marv.
  2. I've wondered about that myself, but can't find a way to turn off the warning.
    At any rate, PrintCD is quite decent otherwise, so to me it's a minor annoyance. I don't think you'll find any freeware or adware that comes close to it. JMO. Maybe someone can suggest some payware that would be acceptable.
    And welcome to the forum.
    Pull! Bang! Darn!
    Aug 2006
    You might look at Acoustica CD/DVD Label Maker. http://www.acoustica.com/cd-label-maker/ I don't know if it will behave better, but I think they have a trial version, and it isn't terribly expensive to buy if you like it.
  4. I did this a long time ago.
    I'm not sure it's the same as v2. In my version (1.4), you could never manually set it below 18mm.
    In order to get the inner hole size I wanted, I created a reg file.
    I clicked merge, then started the Epson software
    Here's what my reg file looks like
    Windows Registry Editor Version 5.00
    [HKEY_USERS\S-1-5-21-1409082233-1060284298-1417001333-500\Software\CORPUS\EPSON Print CD\Printings]
    "Bore"=dword:0000000f
    This sets the inner hole to 15mm
    This string is dependent on your computer "S-1-5-21-1409082233-1060284298-1417001333-500" this just happens to be tied to my SID
    You can do it manually each time with regedit, just choose decimal instead of hex and it will show you the inner hole in mm
    Looks like v2 moved to a new reg key
    [HKEY_USERS\S-1-5-21-1409082233-1060284298-1417001333-500\Software\EPSON\Print CD\Printings]
    "Bore"=dword:0000000a
    Still I can set the inner hole "bore" to any mm I want using regedit. In this case with a little "a" instead of and "f" it went fron 15mm to 10mm
    Funny how mine via the software (v1.4 or 2.0) is always limited to 18mm
    Originally Posted by jagabo
