Hi,
recently I downloaded RipBot264 and I've been getting a couple errors and I think it may have to deal with Avisynth of ffdshow.
Well, I installed all Codecs up to date - I have a Windows XP OS and whenever I try and convert my video using RipBot264,
I get 2 different types of error and I can't tell which is which.
The same videos will get the same error.
I try and encode this AVI video which is 1.5 gigs (uncompressed) with audio and I get this error
http://d.imagehost.org/0780/ripbothelp.png
Whenever I try and encode a clip without audio (4.6 gigs, uncompressed) I get this error
http://b.imagehost.org/0558/ripbothelp2.png
Can anyone help? I wanna convert one of my videos to mkv unless someone else has another program that could do it.
I've installed all codecs up-to-date.
For some reason I can't open my ffdshow video decoder, when I edit, only the Audio decoder shows up in the system tray but my video doesn't.
Can you play the avi with windows media player?
Or just convert with something that does not require any codecs like xmedia recode or handbrake. -
Then it wont work. Try reinstall ffdshow, http://sourceforge.net/projects/ffdshow-tryout/files/SVN%20builds%20by%20xxl/win32%20g...7.exe/download or latest build https://www.videohelp.com/download/ffdshow_rev3631_20101115_clsid.exe
If I install the necessary codec to be allow my Windows Media Player to play AVI, the Ripbot program would work right?
Well, I downloaded the K-Lite Codec Pack (Full) and it basically like uninstalled most of my codec and installed new ones, windows media player works fine
but after i download Avisynth and haali media splitter, some avi's on my computer won't run on windows media player.
And on RipBot264, whenever i try and encode a movie with sound, it just stays like demuxing... and like it won't finish,
The AVI im trying to use in Ripbot is around 1.5 gigs (uncompressed).
what should I do? -
Well I got the decoding going, i dont know how but it finished render, and It renders it to desktop but now I can't seem to find the file anywhere, help!
Ripbot264 1.17
By rapunzel in forum Newbie / General discussionsReplies: 7Last Post: 6th Jan 2012, 17:05 -
how does Ripbot264 think ... ?
By zero7404 in forum Blu-ray RippingReplies: 42Last Post: 3rd Oct 2011, 20:23 -
Ripbot264 Problem! Please help!!
By iS70rM in forum Blu-ray RippingReplies: 0Last Post: 9th Jul 2010, 18:39 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Ripbot264 hanging
By ma2kp in forum Blu-ray RippingReplies: 7Last Post: 13th Nov 2008, 09:59
