Results 1 to 18 of 18
    Dec 2009
    China
    Brothers; tell me how to convert Blu-ray 50GB 25GB, can be said that the next step? Thank exchange with success stories. online and so on.
    Dec 2009
    China
    Originally Posted by mrswla View Post
    The software I've tried quite a few out. often can not keep some of the sound. If: DTS-HD directly converted to AC3. Upstairs The brothers can talk about how to effectively set up? I would like to complete the entire disk compression, a voice subtitles Are many. Thank you.
    Setting can provide me? Line and so on.
    Nov 2005
    decrypt it with anydvdHD then use handbrake to mkv it to the size you want
    Dec 2009
    China
    It can be said with BDrebuilder under the settings?
  5. If you want to keep the HD audio sound then make sure your bdrb setup is correct. It should look like this:
    Dec 2009
    China
    [Attachment 4789 - Click to enlarge]
    Settings can be saved this way completely blue it?
  7. Originally Posted by kimis View Post
    I'm not exactly sure what you are talking about. If you want to keep all original audio that is on the BD50, then check the boxes that I showed and you will be good.
    Dec 2009
    China
    I want to keep all the original audio and subtitles. How do I set?
  9. If you want to keep all original audio and subtitles then make sure you have all languages selected under audio and subtitles.
    Dec 2009
    China
    Thank you mrswla sincere answer, I will test next.
    Dec 2009
    China
    [Attachment 4806 - Click to enlarge]
    Brothers! How do Blu-ray add sound subtitles? what software?
  12. Member ricoman's Avatar
    Jun 2004
    CT, USA
    He just showed you what to do! BDRebuilder. He can't make it any clearer.
    I love children, girl children... about 16-40
    W.C. Fields
    Dec 2009
    China
    I want to add sound subtitles in the movie inside it?
  14. I don't see how you can do it within BDRB.
    You can, however, add a subtitle track with tsMuxer to a movie-only authored BD. Add the playlist file (*.mpls) for the main movie, then add the subtitle track. To add a subtitle track to an authored BD *with* menu(s), you need another authoring tool, maybe multiAVCHD can do it, I dunno. If it can't, then it can't be done with freeware. You'd need to buy a more elaborate authoring program.
    Pull! Bang! Darn!
    Dec 2009
    China
    The movie has a good number of m2ts files ah! tsMuxer not be solved.
  16. I'm a MEGA Super Moderator Baldrick's Avatar
    Open the playlist file(mpls) in tsmuxer. Use bdinfo to identify what playlist to open.
    Dec 2009
    China
    Thanks: Baldrick.
    Master file can be found by bdinfo mpls, synthesized in the tsmuxer a single master file. My original disk is a good number of m2ts, the synthesis of functionality after loss of the menu.
