Hi, I've been trying to install this for a while now and after going through the forums and trying to figure it out myself, I am at your mercy. Can anybody help and let me know what to do. I got myself all confused now. I'm pretty sure I have the right files but I'm guessing there is a underlying problem here.
"##mkdir: /usr/local/lib: File exists" is what comes up when it says the installation was not successful.
Please help, from what I have read this program seems awesome. Thanks
This issue has come up once before, although it stayed unresolved...
It seems however that most users are not affected by this, so the underlying problem is likely specific to your setup.
If you are using a user account with administrator privileges and your boot volume has correct permissions and you followed the install directions on the website, then I have no new suggestions to try and solve this at this time, unfortunately.
Edit: The weird thing is, ffmpegX shouldn't do anything with or in /usr/local/lib -- as far as I know. Its support files are stored elsewhere. It makes me wonder: where did you download your version? And which version is that?Last edited by Case; 19th Dec 2010 at 22:11.
By PhantomAGN in forum ffmpegX general discussionReplies: 4Last Post: 28th Mar 2011, 13:15 -
ffmpegx.com installation
By a.fritz in forum Video ConversionReplies: 1Last Post: 17th Jan 2011, 00:38 -
Installation of ffmpegx
By Docdawh? in forum ffmpegX general discussionReplies: 12Last Post: 19th Nov 2010, 01:13 -
ffmpegX Installation problems....
By maiof06 in forum ffmpegX general discussionReplies: 1Last Post: 31st Aug 2008, 02:32 -
ffmpegX installation
By barry3333 in forum ffmpegX general discussionReplies: 38Last Post: 25th Feb 2008, 20:43
