All,
I am trying to synch a DVD movie which has spanish audio dubbed. It was originally a hollywood production originally shot in English (it has not be released on DVD in the english speaking world yet!). I have a VHS version as well that has the english audio. My goal is to strip the dubbed spanish audio and replace with the english audio from the VHS...
My issue is that the DVD version with spanish dubbed audio is about 5 mins shorter than the VHS version...Point worth noting is that NO scenes have been cut...so it is a playback speed issue where the VHS version plays slower than the DVD version.
I managed to synch the beginning of the spanish audio to the english audio (based on some specific background sounds) and when I do just that the english audio lasts 5 mins longer than the spanish audio.
I went one step further and used the "Time Stretch" option within Soundforge and try and make the audio "stretched down" to match the exact size of the spanish audio. BUT I still see issues with the audio synch...it starts out fine and then about half way into the movie I can see places where the audio is upto 4 seconds off and then around 3/4th of the movie it is about 2 seconds off and by the end it is of by about a second...so as you can see I have varying synch issues - it is not consistently increasing or decreasing.
Can any expert here please recommend a good way to solve this problem...I thought of one way which is to synch parts of the movie until the synch issues start and cut out the correctly synched portion and save as a seperate WAV file...then start with the next portion of the movie - synch it up...cut out a portion in synch and save as a WAV....essentially keep repeating this process where I have a series of WAV files and then i finally thread these WAV's into a single file...Is there a better way to do this.
Also, I am open to other software's that people recommend may be better...so if you feel there is a better software to do this better please feel free to recommend.
You probably have to do it the hard way. Set key frame (M key) markers at intervals and speed correct that segment. Preview for lip sync then move to the next segment. If you still have lip sync error, divide into smaller segments.
Or you can get fancy and non linear spline your audio speed as an event FX.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Perhaps PluralEyes might work for you. Haven't used it myself however.
http://www.singularsoftware.com/pluraleyes.html
GA
Sony Vegas render issue
By greywind in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2011, 19:57 -
Sony Vegas "Black Screen" Issue
By Ruro Jiruries in forum EditingReplies: 7Last Post: 11th May 2011, 09:58 -
Sony HDR CX115e audio issue
By subba in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th May 2011, 12:57 -
Sony Vegas de-interlacing issue
By Vman94 in forum EditingReplies: 16Last Post: 2nd Dec 2010, 01:17 -
quicktime pro will exporting to h.264 solve this huge file size issue?
By cybershot in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2010, 22:43
