My fraps audio and video is out of sync. I hear the audio, before the event happens in the video.
Specs:
CPU: intel core i7 860
GPU: Ati radeon hd 5850
RAM: 2 x 2gb of ddr3 memory
OS: windows 7 home premium
MOBO: asus p7p55ws supercomputer.
SOUNDCARD: Onboard
Fraps setup:
60fps
half size
mic and win 7 sound
I have had fraps working before, I have around 800+ videos up on youtube with 1.5k subscribers waiting for new videos.
I have tried:
-reinstalling Realtek HD audio drivers, ATI drivers and realtek ethernet drivers
-deinstalling my codecs (lame mp3 acm and xvid)
-defraging my HDD
-optimizing PC with Ccleaner registry tool
-freeing up HDD space
-googling like hell
-Trying different media players.
-trying multiple games
-reducing graphics settings in games to lowest
-reducing fraps FPS capture to 30 instead of 59.7.
-set sampling rate of audio 44.1 khz instead of 48.
-reducing res to lowest (like 600x250 or something)
-tried using stero mix.
-using no mic.
-multichannel setting on fraps
-syncing up audio in sony vegas (didn't work audio stream is the same length as video stream)
-syncing up audio and video in virtual dub (same as above)
-contacted fraps support (no reply after 3-4 days)
-searching these forums for a solution
Nothing seems to work, always the delay starts at like 2 seconds and gets worse and worse.
I would be really gratefull if someone will help me.
Regards,
dxdiag
My only thought is to check for dropped frames in VirtualDub using SHIFT+].
Fraps video and audio out of sync
By b-subs in forum Video Streaming DownloadingReplies: 24Last Post: 21st May 2013, 04:50 -
How do I correct out of sync audio using Fraps, or avoid it
By Didz in forum Capturing and VCRReplies: 3Last Post: 10th Sep 2011, 13:42 -
Fraps Audio Out Of Sync
By combatsimulation in forum AudioReplies: 1Last Post: 10th Sep 2011, 11:31 -
Funky Audio & Video Sync Problem [FRAPS]
By Sniff211 in forum Video Streaming DownloadingReplies: 12Last Post: 7th Jul 2010, 10:05 -
Any Simple Fix for Fraps or Xfire codec videos showing up green in avidemux
By ZZen in forum EditingReplies: 2Last Post: 6th Jun 2009, 14:51
