Can someone help me locate a particular sound card that can do the following?
1.) can *decode* DD and DTS
2.) has a TOSLink optical digital input that accepts DD/DTS 5.1, not just stereo PCM
3.) has a TOSLink optical digital input that works with the analog output, meaning it will convert the digital 5.1 sound to analog 5.1 output
4.) has multi-channel analog output
5.) has PCI slot
Unfortunately, documentation for these is sparse.
So I would appreciate anyone who has experience with this to share their knowledge.
Sorry if this seems like a repost. There is another thread I created that is somewhat similar to this. That one was more general in nature about sound cards, receivers or stand-alone decoders. This one is more specific in nature, regarding sound cards.
Results 1 to 30 of 32
Check out creative labs xfi series. I think xfi is still their main lineup. They have multiple sound cards that fit your requirements. If they are not the "latest" that creative labs has either check out online auctions for used models or visit www.creative.com for the latest series they are selling.
In my book you can't go wrong with creative labs products. I've been using them since I got a 8 bit mono sound card way back in the dos 5.0 days (I think that was an Isa card - can't remember exactly what slot type it was but it was way before pci).
Originally Posted by stealth3si
But you can manually output each one and you can even manually send out the center and sub but you have to split the headphone jack output and use trial and error to figure out which one is center and sub.
The tricker part will be getting the model with fiber optic input. They do exist but you have to be sure it is there.
Also check that it does say dolby digital and dts on the product spec. If they do than they will process them and not just "pcm stereo". As long as they label them they have the decoders.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Many of the current products with optical S/PDIF in have PCI-e interfaces. That didn't leave many moderately priced PCI options. Looking at Newegg I found one that may do what you want. http://www.newegg.com/Product/Product.aspx?Item=N82E16829271001 You may see something wrong with the specs that I missed because sound cards/sound systems aren't really my thing.
Here's the manual http://www.htomega.com/filedown/striker.pdf See page 24 regarding DTS or DD, input through S/PDIF and output using analog speakers.
[Edit] Forget it. I missed something. The manual says this: "Note: Non-PCM data cannot be recorded and monitored." It apparently only passes through to S/PDIF output if given non-PCM input.Last edited by usually_quiet; 19th Dec 2010 at 10:36.
Also I forgot to mention my creative xfi card (pci model - the extreme gamer edition) does have a fiber optic in and out port BUT it is external. It is a "flexi-jack" adapter that plugs into the digital i/o jack on the card (a 3.5 mm jack).
Usually this is a separate purchase that has to be bought at the company website as well. Some packages have it included but not all.
As usually quiet mentioned you'll have to dig hard into manuals to make sure this will work as an amplifier from the source.
In the end you might be better off getting an inexpensive second hand free standing amplifier with fiber optic inputs and official dd/dts decoding. A real stereo is truly the best way to do this if this is intended for watching movies in surround sound.
Edit - and you don't have to get a fancy hdmi model. Regular standard definition 5.1 audio still sounds excellent. And if you are worried about bluray don't be. I get it downconverted automatically from my ps3 via fiberoptic to 5.1 dd or dts without a hassle. My amplifier is quite old and is not hdmi but does 5.1 dd and dts standard definition audio perfectly.
Plus just make sure you get speakers that match the wattage of your amplifier and you'll do fine. They don't have to be premium speakers to sound good. Just make sure they aren't less power than amplifier to avoid the risk of overpowering them.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I suspect it will be difficult to find a sound card that has TOSLINK or S/PDIF inputs that accept and decode AC3 and DTS. Hollywood has been working very hard to prevent recording of multichannel audio. To get an AC3 licence you have to agree to such restrictions.
I was curious to check out a Audigy 2 ZS cnet review and reviewer #7 said it does DTS/DD via optical in.
I also stumbled upon the Creative Xi-Fi Elite Pro User Guide (at the very bottom) and it seems to be able to decode DD/DTS signals from an external DD/DTS DVD player via optical connection using their drive or console. But I can't find any information whether either would accept digital 5.1 from here or only stereo PCM.
The Audigy 2 doesn't seem to have a DAC AFAICK but I could be wrong.
The XiFi however has a DAC but I'm not sure if it has anything to do with converting the DD/DTS 5.1 to analog multichannel. Perhaps it's only digital stereo PCM input to analog stereo output? It'd be wonderful if it was digital 5.1 ---> analog 5.1!
Both have multichannel analog output. That's good.
What do you guys think about the possibility of these to do what I want, as far as the three are concerned?Last edited by Stealth3si; 19th Dec 2010 at 21:59.
Starting bids for the Audigy 2 Hub on Ebay are about $10.
http://cgi.ebay.com/CREATIVE-SOUND-BLASTER-AUDIGY2-HUB-MODEL-SB0290-/110624211698?pt=L...item19c1b782f2Last edited by jagabo; 19th Dec 2010 at 22:06.
Gosh - thanks for the last minute link! Haha.
I have no clue as to what proprietary cable is needed to plug that sucker into Audigy 2 (non ZS BTW).
I think this would probably fit my card.Last edited by Stealth3si; 19th Dec 2010 at 22:13.
I thought maybe it was a small A/V amp but it looks like it's just an I/O breakout box.
I think you should to the safe route and find a small A/V receiver. -
Well, there is this listing for another product in the audigy 2 ZS line on bonaza, and based on the picture, it may include everything that originally came in the box http://www.bonanza.com/booths/ecoveauction/items/Audigy_2_ZS_Platinum_Pro_PCI_Sound_Ca..._with_external
Specs say it decodes DD and DTS. The manual can be downloaded here http://support.creative.com/manuals/download.aspx?nDownloadId=7127&prodName=Audigy%202...uide%20English
I don't know anything about bonanza vs. ebay. -
Thanks. I'll probably try out the audigy 2 series out first. I already have an Audgy 2, SB0240 Part ID I believe, which supposedly can decode DD/DTS but to confirm this I'd need an external hub to go along with that and once I pair them both with KX custom project drivers, they should be able to do what I want.
The external hub/module in question looks quite a bit different than the one for the Audigy 2 ZS Platinum Pro and can significantly sell for considerably less than the Audigy 2 ZS Platinum Pro. I just can't seem to find one for sale.
As for the manual, it completely downloads but I can't seem to get any info from it as it says "Invalide Page." or something. -
Follow the instructions in the red box at the bottom of the download page.
Yes, what I linked to is much more expensive, but then again you may wait a long time for the right external module to be offered for sale. ...and afterwards you may have to look for missing pieces that go with it.Last edited by usually_quiet; 20th Dec 2010 at 12:59.
From the red box at the bottom of the download page I linked to:
Due to the high security level on the Windows XP Service Pack 2 platform, the manual might not display correctly. If this occurs, follow these steps to view its contents successfully:
Save the manual on your computer.
Right-click the manual and select Properties.
Select the General tab, click the Unblock button, and then click OK.
The manual should display correctly when you open the file again. -
There seems to be nothing wrong as far as I can tell. I just clicked on the link in my post again to test, and went to the right page.
Try clicking "Quickstart User Guide" here: http://support.creative.com/Products/ProductDetails.aspx -
Thanks. I got the manuals to display correctly.
Both manuals say the cards do decode DD/DTS via TOSlink Optical input if I'm using an external Dolby Digital/DTS DVD player. But I'm not sure if I would get full surround sound out to the 5.1 analog speakers.
Also, would I get the same result if I'm using a WDTV Live in lieu of the DVD player? -
Then you already have a power splitter and an internal firewire cable (assuming you want to use the firewire port) on hand? Be careful about the ribbon cable. Creative warned about substituting a different cable for the the AD_EXT in something I read. You'll need to check the pinout to be sure you have a proper replacement, unless you can find the real thing.
This has a good picture of the cables and other accessories for the Audigy 2 platinum
http://www.anycpu.com/projects/diypc/GraniteBay/SoundCard.htm
The Audigy2 Drive is powered, so you need the splitter. This article http://www.xbitlabs.com/articles/multimedia/display/creative-audigy2.html# describes installation as follows
The communication unit of the Platinum package is installed into a free 5-inch bay of the PC (in Platinum eX this module is external). It connects to the sound card with a special band cable and an adaptor cable for FireWire. Besides that, the Audigy2 Drive receives additional power, necessary for optical sensors, IR-receiver and other radio-electronic units of the module. -
Here's your chance at 2 Audigy 2 drives: http://cgi.ebay.com/Lot-2-CREATIVE-SOUND-BLASTER-AUDIGY-2-SB0250-/270680873778?pt=LH_D...#ht_3377wt_901
...and another apparently complete Audigy 2 ZS Platinum
http://cgi.ebay.com/Sound-Blaster-Audigy-2zs-Sound-Card-SB0350-SB0250-/160520556165?pt...#ht_571wt_1135Last edited by usually_quiet; 21st Dec 2010 at 23:24. Reason: Add 2nd listing
The second one would probably be my choice.
Though, if I can stretch my budget further and find good steals, I might consider used items of the X-Fi Platinum Pro and X-Fi Elite Pro.
As for the firewire, would I connect it from the front panel to the back of the card? What particular purpose would that serve? -
As I understand them, the instructions that I quoted say the internal FireWire cable would connect the Audigy 2 Drive to a FireWire header on the Audigy 2 sound card. It provides a firewire connection at the front of your case. Replacement cables are scarce. This looks like it would work http://www.txcesssurplus.com/servlet/the-6153/Alienware-Area-dsh-51-32%22-Internal/Detail However, the original cable is about 2 feet long.
Taking another look at it, the power splitter appears to be molex to floppy. If your power supply has an unused floppy connection, you could connect that instead.
This has information about what to use as a replacement for the AD_EXT cable.
http://www.hardwareheaven.com/audio-general-technical-discussion/95081-using-ide-cable...num-drive.html
I think they mean this: http://www.amazon.com/IDC-40-inch-Single-Device/dp/B002L0WC7QLast edited by usually_quiet; 22nd Dec 2010 at 17:34. Reason: removed repeated word
what's a good sound card to use for my captures?
By kukuo522 in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2008, 20:53 -
mkv/ x264 support in HTPC software-good?
By bigshotceo in forum Media Center PC / MediaCentersReplies: 1Last Post: 28th Dec 2007, 08:51 -
What good browser is there for htpc use on a 32 inch lcd hdtv?
By yoda313 in forum ComputerReplies: 14Last Post: 21st Dec 2007, 08:25 -
Is This a good deal for an HTPC?
By hype88 in forum ComputerReplies: 15Last Post: 4th Oct 2007, 07:46 -
My HTPC is very unstable when it comes to sound.
By xtrips in forum AudioReplies: 3Last Post: 14th Jun 2007, 13:46
