hi all! just wondering if my htpc can have a nice interface i.e. movie scraping and nice catalog of artwork for all my mkv movie rips. its a 780g chipset so I need a player that can use that hardware for decoding hd.
right now I just use the stale looking mpc hc player which does a great job. Just want to see if Im missing out somewhere.
Results 1 to 14 of 14
Boxee definitely supports DXVA. I don't know if XBMC supports it directly but I've read about alternative players that work with it:
http://forum.xbmc.org/showthread.php?t=61355
It looks like you can also use MPCHC:
http://forum.xbmc.org/showthread.php?t=70727 -
All programs using DXVA should get about the same performance on a particular graphics card.
ok so xbmc isnt outputting any sound over optical even though Ive setup it to do so. boxee is outputting audio in 5.1 over optical. I love boxee interface and it found all my movies and put covers and whatnot. however it doesnt handle fullscreen mkv's very well. they playback very jerky and audio gets out of sync pretty bad. letterboxed mkvs do okay. a little jerkiness but watchable and audio is perfect in sync.
anyway to get xbmc to play with my spdif audio line? i put the sound to analog and it plays audio but only 2 channels. so I get no dialog from the movies only front R/L audio. -
I don't know much about XMBC. Can't help you there.
I did notice that Boxee had very high CPU usage (Athlon64 X2) while playing Apparently it's not using hardware decoding even though it's enabled in the options. That computer previously had a Nvidia graphics card in it. I seem to remember that working much better in the past. -
A Win7 vs XP issue? I was running XP.
I did see someone was working on a way to integrate MPCHC into XBMC. I don't know how well it worked out.
<edit>
Ah, found this from a Boxee developer:
http://forum.xbmc.org/showthread.php?t=63605&page=2DXVA for Win XP is only through DShow so we're not using it.
</edit>Last edited by jagabo; 19th Dec 2010 at 20:49.
ahh that makes sense then why I am seeing differences from xp to win7
cool I have got mpchc running with xbmc!
im putting windows 7 on htpc and see how that does with audio issues and dxva2 will report back.
well I had some audio troubles again and now I dont know how I got it to work but it works now. 5.1 digital optical out! sweet. I had to change my windows 7 resolution to 720p and xbmc as well because it was too laggy. Guess my comp is not enough to handle all the artwork that is xbmc.Last edited by craig198; 21st Dec 2010 at 20:36.
How to save Re:Quality guide for HTPC, how to configure MPC-HC, ffdshow, et
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2011, 09:09 -
HTPC Guide with mpc-hc ffdshow reclock madVR... on HomeCinema-HD
By je_rem_y in forum Software PlayingReplies: 0Last Post: 12th Feb 2011, 09:53 -
WMP/WMC won't play Subtitled MKV's, MPC will?
By Rantlers in forum Blu-ray RippingReplies: 1Last Post: 28th Apr 2010, 06:54 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 11:52 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 22:41
