I have been using sony vegas pro from a while and now I want to try another editor to learn some new but I am confused which editor to pick now?
I have seen few editors like...
Final cut pro
Adobe Premier pro
CyberLink Power Director
Corel Video Studio pro
etc
Any non fan boy or non biased suggestions please.
Results 1 to 11 of 11
Are there desired features missing in Vegas Pro that you think would be found in another NLE? (Unless your experience is with demos alone, this could end up being a costly switch.) You mentioned Final Cut Pro; are you planning to edit on a Mac?
Unless we know more about your needs and preferences, it's difficult to address your request. It's kind of like you're asking if a Black & Decker hammer is better than a Craftsman hammer. The Pro versions of most NLEs will do pretty much the same sorts of tasks. Variations involve user interfaces and how they integrate with other software. -
Try the demos for each and form your own opinion.
Of your list, Adobe Premiere Pro and Final Cut Pro have the same chief designer and follow a similar UI philosophy. Vegas attacks the same Pro user type with a novel UI. Not on your list is AVID that is focused on long form fine cut editorial and less on effects editing.
Cyberlink PD and Corel VS (also Adobe Elements and Pinnacle Studio) are targeted at non-pro newbies.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If you want to learn something new, try learning the inner workings of Vegas and how each of the filters and effects work and what they are good for, then learn about compositing and masking, then learn how to animate, mask, and apply effects using keyframes, then you will realize that Vegas Pro is much more capable than you previously thought.
P.S. I despise Sony.Last edited by budwzr; 18th Dec 2010 at 21:28.
Sony bought the Sonic Foundry products long after Vegas was released. Fortunately, the Madison WI development team was left semi-independent to extend the product line. Even support is done from Wisconsin.
Right, it's "Made in America". So at least the English in the manual makes sense. And it's actually built as a native Windows App unlike a "Macromedia" interface, like Adobe and Magix where you feel like you're in a "virtual window" resource hogg.
I was a long time Premiere user but switched to Vegas for stability, multi-instance and network shared rendering. Vegas is rock solid and fast. I still use Premiere Pro for heavy layered graphics mostly because I'm used to it and it is more tightly integrated with other Adobe products. I also use Final Cut for Apple centric projects.
well I am not unsatisfied with the vegas but as everyone knows video editing require huge leaning curve that's why I started with vegas, have done alot in it but before giving it too much time I just want to make sure that I am spending my time on a good editor. So everyone is suggesting that i should stick to it?
2-way splitter or A-B switch?
By CSULB71 in forum DVB / IPTVReplies: 4Last Post: 29th Dec 2010, 08:50 -
A-B Switch Box?
By MourningStar in forum Newbie / General discussionsReplies: 8Last Post: 9th Mar 2010, 19:41 -
Need to switch from SVHS to ?
By lavapen in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2009, 21:18 -
Can you switch from Vista to XP?
By NBninja8 in forum ComputerReplies: 37Last Post: 23rd Dec 2007, 23:06 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 09:23
