I'm slowly getting the hang of ripping my BR to WDTV format properly. With AnyDVD running I ripbot to the streams, it demuxes and then I recombine them mkv 8.5G as per the recently added guide. Still thrown for a loop on True HD BRs... another story.
My question is: Is it possible to replace the standard x264 encoder that ripbot uses with a comparable CUDA capable app?
I love seeing all my 6 cores at 100% but still dreaming of cutting the time down even more using the GPU.
I realize the pitfalls of CUDA dreams but was wondering if newer mainconcept or mediacoder etc apps could be swapped in?
Sorry, I'll probably always be a video newbie... but I'm trying.
x264 encoder will ALWAYS give you better quality than any CUDA based encoder!
An "Cuda/GPU Optimized Version" x264 Encoder would be nice.
While GPU processing may not be perfect, an x264 encoder optimized with some GPU tweaks could speed things up without giving up quality. If quality is the number one factor - why compress at all? Terabyte drives are cheap... -
according to x264 developers it is almost imposible to port all necessary parts of x86 code to cuda. At least it would require to much work.
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 14:01 -
HexEdit DVD Player Firmware -- "REPLACE CHKSUM"??
By dursman in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2009, 10:55 -
Guide "Replace DVD Menus With VobBlanker"
By skaleton in forum Newbie / General discussionsReplies: 2Last Post: 30th Aug 2008, 13:12 -
"Where's progress app?" error when trying to decode VCD
By rossi in forum ffmpegX general discussionReplies: 8Last Post: 19th Aug 2008, 01:48 -
ffmpegX jumps to "finished" crashes computer, lost progress.app
By jegler in forum ffmpegX general discussionReplies: 16Last Post: 2nd Jun 2008, 20:53
