I am just trying to join several avi files then converting them to dvd as a single file. When I open the avi files in vd i get a error...
"could not locate compressor for xvid
direct show codecs such as these are not suitable"
1. Is there an easier way to join these besides changing the sample rates for each file to play as a single dvd?
2. if not how to i get around this error?
Thank
Lee
Did you install the Xvid codec? If you did, you might need to change the fourcc from xvid to XVID. You can use AVI Fourcc Codec Changer. After that you may get a message about the frame rates not being the same. You can use AviFrate to change both file to have exactly the same Scale and Rate values.
Or you could try using AviDemux which is more forgiving of such things.
AVS script + raw files for frame rate conversion
By 24fps in forum Video ConversionReplies: 7Last Post: 17th Aug 2011, 03:10 -
Pinnacle Studio 12 frame rate error for Panasonic AVCHD Lite mts files
By dewispew in forum EditingReplies: 10Last Post: 13th Jul 2009, 02:13 -
Getting the wrong frame rate with mts files.
By tomhanks in forum Software PlayingReplies: 8Last Post: 24th Jan 2009, 17:02 -
frame rate error apending avi with Virtualdub.
By lilith2014 in forum Newbie / General discussionsReplies: 13Last Post: 19th Aug 2007, 12:52 -
Joining 2 avi files, error with audio streams, need help
By leinan in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2007, 06:12
