Hi all,
I'm looking for some help regarding a MKV file which I will to burn to DVD. The media is divided into a video stream and 8 ACE audio streams/files. I've found a few guides but these all seem to assume that the vidoe and audio streams are combined. I am guessing I first need to render a file which combines the two before outputting the VIDEO_TS files. That much is straight forward I'm sure, but how do I combine them?
I have tried opening the file in VirtualDubMod but I get an "out of memory bounds" error.
I've also tried using MKVExtractGUI-2 but when I open the video stream the audio streams are not listed.
Thank you in advance,
Rob.
I'm confused.
Do you have a 1 MKV file with these 8 tracks included or do you have 9 files. (I video and 8 audio)? If that's what you have than you would use the MMG function in MKVtoolNix to re-mux them into 1 file.
Tony -
Don't have one to recommend since I've never converted a MKV to DVD and the DVD to MKV programs that I have used don't work for that.
However, if you go to the tool section of this site( listed on the left of the first page) and use the conversion selection feature to convert MKV to DVD 8 tools pop up and most of them are free tools. So, if no one else posts a suggestion, you can download one or more of them and see what you like best.
Tony
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Newbie looking for help on a good cp to use for vidoe editing
By godesdevine in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2010, 19:18 -
Audio and Video not combining
By adeleander in forum ffmpegX general discussionReplies: 9Last Post: 23rd Sep 2008, 16:52 -
Combining Audio and Video in VirtualDubMod
By jwfc in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2007, 22:13 -
vidoe editing program
By romik91 in forum Video ConversionReplies: 15Last Post: 24th Aug 2007, 22:24
