I recently bought a DVB-T receiver (which came as a USB device). The software in the package was ArcSoft TotalMedia 3.5, which can easily capture TV channels.
However, only the software itself, as well as VLC, can playback the sound (video is OK). I took a look at VLC's codec info, and noticed that the captured movie uses AAC codec, as shown below:
I tested Media Player Classic, Windows Media Player, Zoom Player, etc. but none could play the sound. (Well, the KMPlayer could play the sound, but it uses internal codecs.)
More experiments show that ArcSoft TotalMedia 3.5 didn't transcode the movie; So, it uses the original codec as broadcast. I tried ProgDVB 6 to capture the TV, and it nagged that the audio codec is not available.
What can I do?
PS: K-Light 6.40 Mega is installed on my system.
I agree with PDR - it's likely a decoding problem with AAC LATM/LOAS - the newer multiplexed format packaged with Euro broadcasting streams (not necessarily the AAC codec itself).
I've dabbled with several broadcast formats lately (as PDR knows), and from my experience Open Source Software still doesn't have a full solution currently. It's still mostly in the domain of professionalware at this point (Elecard comes to mind). I wish I could help you more, but I'm in Canada and don't have access to the various versions of this format.
Unless someone has a better solution, I'd say stick to the software that came with your purchase for now and hang on to your Source for later.I hate VHS. I always did. -
@poisondeathray @PuzZLeR : Thanks a lot for the quick reply.
Here's the output of MediaInfo.
As PuzZLeR said, it might be that free software can't handle capturing it, but I want to play it back in the first place. The question is, why VLC can play the audio, while others cannot?Code:General ID : 1 Complete name : C:\Documents and Settings\Test\Desktop\TV.mp4 Format : MPEG-TS File size : 25.3 MiB Duration : 59s 892ms Overall bit rate : 3 535 Kbps Video ID : 1003 (0x3EB) Menu ID : 3 (0x3) Format : AVC Format/Info : Advanced Video Codec Format version : Version 2 Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 59s 340ms Maximum bit rate : 3 926 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Color primaries : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM Transfer characteristics : BT.470-6 System B, BT.470-6 System G Matrix coefficients : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601 Audio ID : 2003 (0x7D3) Menu ID : 3 (0x3) Format : AAC Format/Info : Advanced Audio Codec Format profile : High efficiency AAC v2@L2 Duration : 57s 685ms Bit rate mode : Constant Maximum bit rate : 36.0 Kbps Video delay : 823ms Text ID : 3003 (0xBBB) Menu ID : 3 (0x3) Format : Teletext Maximum bit rate : 346 Kbps
Please note that the bundled ArcSoft TotalMedia 3.5 comes with a lot of codecs, which other programs should be able to use. In addition, ProgDVB 6 is not a free software, and given that it is a very famous DVB-T software, I'm wondering why it does have this problem. (Even when I select TotalMedia's codecs.)
PS: Here's a screenshot of ProgDVB audio codecs:
As you can see, it did not detect codecs for AC3, AAC, and OGG. If I click the drop-down besides AAC codecs, I see a list of possible choices:
among them you can see two ArcSoft codecs: ArcSoft Audio Decoder and ArcSoft RealMedia Audio Decoder. Other codecs are present as well, but I can't get them to work. -
The clue is in the MediaInfo report:
This is not the same as the more usual AAC-LC.Code:Format profile : High efficiency AAC v2@L2
http://en.wikipedia.org/wiki/High-Efficiency_Advanced_Audio_Coding
states that this can be played by Winamp and foobar2000 (among others), as well as VLC. -
This should be able to be decoded by ffdshow as well. It might be a splitter problem. File name is TV.mp4 but mediainfo reports it's a transport stream. Try renaming extension to .ts or .m2ts and make sure you have haali splitter installed. Render the file in graphstudio to see if the pins connect (helps in diagnosing directshow filter issues)
@Gavino: Neither Winamp nor foobar2000 can play it. Loading the MP4 in Winamp, it simply does nothing. foobar2000 is a little bit more informative, and gives the following error:
@poisondeathray: It will be excellent if I can play it with ffdshow. As pointed earlier, I have K-Lite Mega installed, so I have haali splitter as well (I double checked to make sure). I tried renaming the extension to .ts or .m2ts , but it didn't help either. Here's the output of graphstudio (note the extension is changed to .m2ts):Code:Unable to open item for playback (Unsupported format or corrupted file (moov box not found)): "C:\Documents and Settings\Test\Desktop\TV.mp4"
It only shows a video stream in TV.m2ts, which is odd!
Converting VFR FLV (H264/AAC) to AVI (other) w/o sync issue
By kwondra34 in forum Video Streaming DownloadingReplies: 43Last Post: 11th Apr 2012, 00:54 -
VLC audio device option issue
By vampelle in forum Video ConversionReplies: 4Last Post: 17th Sep 2010, 11:21 -
VLC Player issue
By garyknowz in forum Software PlayingReplies: 3Last Post: 11th Feb 2010, 06:22 -
VLC & dual screens issue.
By protiek in forum Software PlayingReplies: 3Last Post: 5th Nov 2007, 14:23 -
AAC 5.1 playback problem
By TigerShark in forum AudioReplies: 0Last Post: 30th Sep 2007, 10:08
