Hey guys. I've got a couple videos that I will be burning to a disc for my friend. The problem is that they open in the wrong aspect ratio. I've tried VLC, Media player classic, and Windows media player. All have the same problem.
You can however manually change the aspect ratio to 2.35:1 in vlc and mpc and the videos play as they should, but I would like a more permanent solution as my friend might not understand or remember how to change the AR every time.
The videos open with the top and bottom stretched upwards and downward which make the image blurry and distorted looking. There is a small info file with them, here is the info about the video:
VIDEO
Resolution: 544x320
Aspect Ratio: 1.70:1 Anamorphic widescreen (2.35:1)
Bitrate: 755 kbps
Frame Quality: 0.174 bits/pixel
FPS: 25.000 PAL
They are xvid encoded avi's.
	Thank you so much! I've been trying for 2 days, google nor the help of another forum was getting me anywhere.
 Thanks!
  change default aspect ratio without re-encoding?By boonesmi in forum Video ConversionReplies: 14Last Post: 30th Aug 2012, 11:17
  AVStoDVD: How do I make default settings for all files to aspect ratio 4:3?By Heyjoojoo in forum Authoring (DVD)Replies: 8Last Post: 30th Aug 2010, 23:49
  Wrong Aspect RatioBy weathervane in forum Capturing and VCRReplies: 11Last Post: 18th Aug 2010, 23:18
  wrong aspect ratio ???By clickit in forum ComputerReplies: 3Last Post: 7th Dec 2007, 03:49
  .VOB in wrong aspect ratio, he-lp needed (my wedding video!)By nicknomo in forum Video ConversionReplies: 10Last Post: 30th Oct 2007, 15:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
