Okey guys,I was trying to open a script in VirtualDub and I got an error.
So what's the problem?
Did you just make the D2V file? Open it with Notepad. Does it look like a normal D2V file? Is the filename (in the D2V file) correct?
DGIndexProjectFile16
4
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
VTS_01_4.VOB
Stream_Type=1
MPEG_Type=2
iDCT_Algorithm=6
YUVRGB_Scale=1
Luminance_Filter=0,0
Clipping=0,0,0,0
Aspect_Ratio=4:3
Picture_Size=720x480
Field_Operation=1
Frame_Rate=23976 (24000/1001)
Location=0,0,3,3f2a
d00 6 0 2048 0 1 1 d2 e3 f0 e1 f2 e3 e0 f1 f2 e3
900 6 0 22528 0 1 1 70 71 d2 e3 f0 e1 f2 e3 e0 f1 f2 e3 e0 e1
d00 6 0 53248 0 1 1 d2 e3 f0 e1 f2 e3 e0 f1 f2 e3
900 6 0 83968 0 1 1 70 71 d2 e3 f0 e1 f2 e3 e0 f1 f2 e3... -
Is the source file still in the same location? Any possibility you have an old DgIndex and new DgDecode.dll? Or vice versa?
Yes source is still in the same loctaion,as for the DGIndex I don't know,just downloaded it from here.DVD2AVIProjectFile
1
31 D:\Ghosts\VIDEO_TS\VTS_01_5.VOB
Stream_Type=1,0,0
iDCT_Algorithm=5 (1:MMX 2:SSEMMX 3:FPU 4:REF 5:SSE2MMX)
YUVRGB_Scale=1 (0:TVScale 1:PCScale)
Luminance_Filter=0,0 (Gamma, Offset)
Picture_Size=0,0,0,0,0,0 (ClipLeft, ClipRight, ClipTop, ClipBottom)
Field_Operation=0 (0:None 1:ForcedFILM 2:SwapOrder)
Frame_Rate=25000
Location=0,0,0,7FFAA
7 0 B1 2 2 2 2 2 2 2 2 2 2 2 2
7 0 16D 2 2 2 2 2 2 2 2 2 2 2 2
7 0 230 2 2 2 2 2 2 2 2 2 2 2 2
7 0 2FD 2 2 2 2 2 2 2 2 2 2 2 2
7 0 3BE 2 2 2 2 2 2 2 2 2 2 2 2
7 0 46C 2 2 2 2 2 2 2 2 2 2 2 2
7 0 52B 2 2 2 2 2 2 2 2 2 2 2 2
7 0 5EE 2 2 2 2 2 2 2 2 2 2 2 2
7 0 6B2 2 2 2 2 2 2 2 2 2 2 2 2
7 0 776 2 2 2 2 2 2 2 2 2 2 2 2
7 0 839 2 2 2 2 2 2 2 2 2 2 2 2
7 0 8FD 2 2 2 2 2 2 2 2 2 2 2 2
7 0 9C0 2 2 2 2 2 2 2 2 2 2 2 2
7 0 A84 2 2 2 2 2 2 2 2 2 2 2 2
7 0 B48 2 2 2 2 2 2 2 2 2 2 2 2
7 0 C16 2 2 2 2 2 2 2 2 2 2 2 2
7 0 CDF 2 2 2 2 2 2 2 2 2 2 2 2
7 0 DA8 2 2 2 2 2 2 2 2 2 2 2 2
7 0 E72 2 2 2 2 2 2 2 2 2 2 2 2
7 0 F3A 2 2 2 2 2 2 2 2 2 2 2 2
I get something like with lots of rowsLast edited by Dr.Who; 17th Dec 2010 at 13:45.
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 17:57 -
VirtualDub File [path] does not have a video stream error
By fershad in forum Video ConversionReplies: 4Last Post: 25th Jan 2012, 07:11 -
VirtualDub "NewMovieFromFile" error w/mp4 file
By smk42 in forum EditingReplies: 3Last Post: 31st Dec 2009, 01:37 -
Error while drugging MPEG 2 file to virtualdub
By eliqush in forum EditingReplies: 8Last Post: 4th Nov 2009, 09:53 -
Error in Gordian Knot when trying to load d2v
By php111 in forum DVD RippingReplies: 12Last Post: 5th Oct 2007, 22:32
