I wish to attach subtitles to my .mkv file and watch it on WMP. I downloaded the .srt file and installed the DirectVobSub codec. I copied the .srt file into the same folder as the .mkv file then re-named the .srt file so it was identical to the .mkv file (except the .srt file extension). I opened the folder with WMP and set the subtitles to on (if available) - the sound and vision are absolutely fine, but there's no subtitles!
What am I doing wrong?
When I try to open the SRT file itself (it's a zipped file), Windows tells me that it doesn't have a program associated with it and I should create an association. Then it says Windows cannot complete the extraction - the destination file could not be created. When I go into Control Panel, the .srt file extension is not listed. Is this what's preventing the subtitles appearing? How do I create an association?
Thanks marioval. I installed 7zip, extracted the srt file and saved it into the same folder as the mkv file, with the same name... but it's still not working. When I double click on the srt file itself I still get the same windows error message saying I need to create an association... and the .srt file extension still isn't showing in the control panel.
On your SRT file do the right-click, go to Open with... and choose WordPad.
sounds like there is an error in the srt file
can you open it with notepad?
Extract SRT From MKV
By Valentin in forum MacReplies: 4Last Post: 12th Sep 2014, 21:14 -
embed srt into mkv
By Soixante in forum Video ConversionReplies: 3Last Post: 16th Oct 2010, 05:00 -
How to demux .srt from mkv, then convert .srt to .smi and mux .smi to mkv??
By narayanan in forum SubtitleReplies: 1Last Post: 7th Aug 2010, 23:49 -
Embedding .srt into .mkv
By gauche in forum Newbie / General discussionsReplies: 1Last Post: 17th Apr 2009, 14:51 -
MKV with srt = laggy (?)
By therock003 in forum Software PlayingReplies: 5Last Post: 15th Jul 2008, 14:18
