    Jan 2010
    I'm certain this question is asked frequently on here but I couldnt find anything searching the forums. In short, I'm trying to get the shows I have on my DVR (it had to be replaced but still works for the most part) off and put on a hard drive. Any way to do this?
  2. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Isnt it already on a hdd ??
    *** Now that you have read me, do some other things. ***
    Nov 2000
    Canada
    If you mean break the encoding on the hard drive so you can transfer the content to a PC, the short answer is no. You can't do this for Dishnetwork either (at least for High Definition content). You might check Yahoo groups for that device or a DirectV forum to see what you CAN do...
    Jan 2010
    Thanks for the replies..... I'm a moron with these kind of things but i figure you never know what some of the smart guys have figured out.
