hello everyone,
i have three Ac3 5.1 audio files, which is extracted from three parts of xvid-avi video files.....i just want to join them as one and mux to a different Video source.
i extracted audio using Virtualdub mod, i want just to join the ac3 files with out any conversion also keeping the original channels...........
It can be done from the command line too, as follows:
Change to drive where the files to be joined are located i.e. C drive:
type: copy /b c:\file1.ac3+c:\file2.ac3+c:\filelast.ac3
Then run through ac3 fix to correct joint errors. If you are using ac3fix, then the file to be corrected needs to be in the same folder and I would advise to put the gui in the same folder and use that, it's just simpler. -
Editing & joining AC3 tracks
By carlmart in forum EditingReplies: 1Last Post: 18th Apr 2010, 12:06 -
Joining AC3 files on a AVI or MKV?
By CactusMan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2010, 19:44 -
Joining MPEG2 files with different AC3 audio delay on each file
By Killer3737 in forum EditingReplies: 6Last Post: 27th Oct 2008, 23:32 -
Alternative AC3 cutting and joining tools
By 557953 in forum AudioReplies: 2Last Post: 21st Aug 2007, 11:11 -
Joining M2V & AC3 files for DVD burning, Subtitle creation sub position
By blue2 in forum Authoring (DVD)Replies: 15Last Post: 29th May 2007, 08:56
