this msg appears now when I'm converting my dvd!! Access to the path 'F:\.mpg' is denied. Any idea how to fix it??
	Can you access drive f through explorer? The drive may either be disconnected, or access is otherwise being denied by permissions. First try rebooting and see if the problem persists.
	StangGurl-in the future please use a more descriptive subject title in your posts rather than help,for this time ill change your title. I think,therefore i am a hamster.
	It's looking for a file called ".mpg"
 Which is pretty unlikely, means the real filename has been lost somehow.
 What is the name of your input video?
 if it's something with spaces and punctuation, try renaming it to something short and simple, just letters and numbers, and try again.
	You don't say what program you are using to convert but somewhere in an optional path statement you have typed (or the program erroneously defaults) to a source, temp / working or target path that is invalid. When the program tries to access a file using this path you will get that type of message.
 A filename cannot begin with a period (.) The path 'F:\.mpg' is looking for a file called ".mpg" (not what you might think is implied "blank.mpg" but rather ".mpg.noextent") and that first period is what is invalid in a file name.
 If you intended to have a search path looking for all files that end in .mpg then it should look like this "F:\*.mpg"
 If you wanted a specific file then it should look like "F:\filename.mpg".
 Check all selectable path options in the program(s) you are using and you should find the error.There's not much to do but then I can't do much anyway.
	Thanks!! It was looking for mpg file...got it fixed!! Sorry 'bout "help" as subject...this is my 1st time on a forum!! Thanks for all the help!!
  TMPGEnc Authoring works 4 - Access is Denied (Error code 0x80070005)By The Roo in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2021, 18:34
  Avi2DVD file access deniedBy Imeil in forum Video ConversionReplies: 1Last Post: 27th Aug 2011, 09:29
  Access denied to some files on one of my USB drivesBy cal_tony in forum ComputerReplies: 6Last Post: 15th Apr 2011, 16:53
  avi access denied solvedBy herdofem in forum ComputerReplies: 1Last Post: 4th May 2009, 22:52
  AVI2DVD file access denied messageBy playaa in forum Video ConversionReplies: 3Last Post: 4th Aug 2008, 19:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
