Results 1 to 10 of 10
    Dec 2010
    st Louis
    I have a 264 file and an AC3 file. I use mkvmerge on them but it doesnt work right. I am a total newb. I have attempted many times to MKVmerge them with no luck. can anyone help me.
  2. What is the error message or what doesn't work right ?
    What steps did you take ?
    Your thread title is "reencode". What does this have to do with "reencode" ?
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    English please!!!!!!!
    Well, that at least makes sense......
    Try starting out with what you have and what you are trying to do.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    An H264 file of Gone With The Wind and an AC3 file of a Justin Bieber video is NOT going to work.....something to do with the running time I'd imagine.
    Dec 2010
    st Louis
    Ok.. again I am a newb and sorry for lack of info. I have a m2ts file that plays fine, but I use MKV's for 100% of my playback. I wanted to take that m2ts file and make an MKV minus some Language files. I used TsMuxeR to Demux the file into two files that I want (1) 264 file and (1) AC3 file. I tried using MKVmerge to put them back together. I must be doing something wrong because the file doesn't play right it is jerky and the audio is way out of sync. I tried different framerates with no luck. I just not sure how to get them back together (reencode) so that they work properly.
  6. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    Some things you can try.
    First of all, what does MediaInfo say about your original files and/or demuxed .264 and .ac3 files?
    Second, try remuxing the raw .264/.ac3 files again with TsmuxeR into another .m2ts or even .ts file. Does it play well? How also would it play in an .mp4 file (using a tool like mp4muxer)? I'm wondering if it's an .mkv problem.
    And speaking of .mkv problems, some problems associated with it is when the video source is either interlaced or has pulldown. MKV has difficulty handling those.
    I hate VHS. I always did.
    Dec 2010
    st Louis
    ORIGINAL M2TS FILE MEDIA INFO RESULTS BELOW
    General
    Complete name : C:\xxxx\xxxx\xxxx\tsMuxeR_1.10.6\00000.m2ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 5.27 GiB
    Overall bit rate : 2 bps
    Maximum Overall bit rate : 35.5 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : 27
    Bit rate mode : Variable
    Maximum bit rate : 40.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio #1
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 129
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : 49ms
    Stream size : 805 ?iB
    Language : Russian
    Audio #2
    Menu ID : 1 (0x1)
    Format : AC-3
    Codec ID : 129
    Bit rate : 384 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Bit depth : 16 bits
    Language : Russian
    Audio #3
    Menu ID : 1 (0x1)
    Format : AC-3
    Codec ID : 129
    Bit rate : 384 Kbps
    Bit depth : 16 bits
    Language : English
    ORIGINAL M2TS FILE MEDIA INFO RESULTS ABOVE
    DEMUXED 264 FILE MEDIA INFO RESULTS BELOW
    General
    Complete name : C:\xxxx\xxxx\xxxx\tsMuxeR_1.10.6\00000.track_4113. 264
    Format : AVC
    File size : 1.07 GiB
    Video
    Format : AVC
    Color space : YUV
    Bit depth : 8 bits
    DEMUXED 264 FILE MEDIA INFO RESULTS ABOVE
    DEMUXED AC3 FILE MEDIA INFO RESULTS BELOW
    General
    Complete name : C:\xxxx\xxxx\xxxx\tsMuxeR_1.10.6\00000.track_4354. ac3
    Format : AC-3
    File size : 59.9 MiB
    Duration : 21mn 48s
    Overall bit rate : 384 Kbps
    Audio
    Format : AC-3
    Duration : 21mn 48s
    Bit rate : 384 Kbps
    Bit depth : 16 bits
    Stream size : 59.9 MiB (100%)
    DEMUXED AC3 FILE
  8. mediainfo reports it's interlaced. As puzzler said, mkv container doesn't handle interlaced content very well. Leave it in a transport stream for best compatibility
    re-encoding (+/- deinterlacing) will lower the quality and take a long time (unless you use a lossless format = huge fileszie). I think what you were asking is re-wrapping (just change the container)
    Dec 2010
    st Louis
    It looks like my DEMUXED AC3 is only 21min and 48 seconds.. IT SHOULD BE 1hr 36min. So no easy way to change container
    Dec 2010
    st Louis
    Well if I have to leave it in m2ts format thats fine.. So how do I change audio streams in Win7 Windows Media Center?? I usually use this program called media control that works with ffdshow so I can select the audio I want but I have no such option when playing the m2ts file. I think its playing it natively to Win 7 WMC.. Install a filter maybe?? My player for everything is Win 7 Windows Media Center and I don't want to break functionality with all my other MKV's just to play this one file.. Any suggestions. OH and THANKS To all that have replied. So far this is the best forum I have ever used for video related info.
