Hi guys,
I was windering how to extract an HD video from sony HDR-XR550 camcorder?
I tried to extract but I couldn't select any video using the PMB Launcher
Hope to find help
Thanks in advance![]()
It is semi-solved actually
I managed to import the videos from the camcorder to my computer using the PMB, but when I tried to edit the video it was not in HD ?!
And when I played the video using "Media Player Classic - Homecinema" it shows waves on points of movement ? Is it because of my laptop or something about the RAM or it's just the camcorder? -
my uncle has the same camera and the only way to import that data is thru that pmb software unfortunately....also playing those vids with MPC did the same as u mention....of course, thru the sony software it looked and played fine...maybe one day some1 will get us to the point where we can edit hd fiels as simply as we can dvd...I'm guessin thats the way they meant for it to be though
i just ran the video thru Multiavchd and down converted it to dvd...you might could also try tmpg authoring works/express as an alternative to see if it can handle those HD files
How about the Sony HDR-XR150 Camcorder?
By jbitakis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 4th Aug 2010, 18:07 -
sony hdr-sr12 new HDD camcorder is 1080p or 1080i?
By deejay.2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 31Last Post: 8th May 2010, 14:04 -
Creating DVD from Sony HD camcorder HDR SR11
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2010, 08:46 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
Re: Sony Digital Camcorder HDR TG3E Various
By billbirchall in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2008, 13:06
