I tried to get the sound to work on my computer today and it wont work. I went to "Sounds and Audio Devices Properties and all of the volume section tab, the audio section tab, and the voice section tab are completely grayed out. I cannot click anything. The icon for volume has also disappeared from the icon tray. It also indicates that there is "No audio device" Which is odd seeing as how there was yesterday. There is a stupid girl in the house that is always on downloading random crap also.
I have crappy generic speakers that have never failed on me before. I know the sound still works on them also because my ipod works just fine on them. I tried headphones and they also wont work. I have tried front and back ports as well. In the "Sounds and Audio Devices Properties" box under the hardware tab, here are the following items:
HL-DT-ST DVDRAM GSA-4167B
Audio Codecs
Legacy Audio Drivers
Media Control Devices
Legacy Video Capture Devices
Video Codecs
I am alright when it comes to using computers but I would really appreciate some help. Thanks so much in advance!![]()
hi and welcome to the forum!
sounds like your audio hardware has been uninstalled from windows. not sure how or why it was done, but you have a couple choices. you can try to "go back" to a previous date where it was still installed with the windows restore function, or you can try re-installing the devices.
re-installing is probably the better of the choices. i would go to the website of the manufacturer of you computer and go to their support section and search for your model. download the latest version of the audio hardware drivers and install them. -
Try installing your sound card drivers again..
" Who needs Google, my wife knows everything" -
Something like this may work (depnds on your exact version of Windows):
Start menu: click though:
Settings
Control panel
System
Hardware
Device manager
Now you'll see a string of you devices.
The audio drive probably under "Sound, video and game controllers"
If you have a sound device there, it may be turned off. Of it may have a yellow exclamation mark, indicating some error.
R-click, properties.
First see if it's enabled: if not, enable.
Otherwise try "uninstall"
Then look at the top menu and choose "Action/scan for hardware changes".
With any luck Windows will find the "new" audio hardware and reinstall the audio driver.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 11:39 -
audio problem
By harariman in forum AudioReplies: 10Last Post: 7th Jan 2009, 22:31 -
problem with Audio
By cgguy in forum AudioReplies: 1Last Post: 14th May 2007, 07:48
