Results 1 to 16 of 16
  1. using a sony vaio comp with a hp 1170 external burner.the internal broke down a while ago and is too expensive to fix.using the external fine for a while and using it alot.alot.I thought it was the dma thing cos when I uninstalled and rebooted it would fix it for a while anyway.this went on for months.now that fix won't help.it would take a couple hours to rip and burn.firmware and drivers updated.burner does seem to make more noise too.on vista if that makes a diff.there are 3 ata channels 0 0 and 1 only see dma in the middle one 0.the others don't have anything in properties to inc=dicate dma enabling.to make mattters worse getting some burn fails now.on different media not just one.this is happening on dvd shrink and nero, which I unistalled clean tooled tried again with no luck.this is the burn fail log if that might help.maybe its just the burner?thanks for any other ideas
    Windows XP 6.0
    IA32
    WinAspi: -
    NT-SPTI used
    Nero Version: 7.8.5.0
    Internal Version: 7, 8, 5, 0
    (Nero Express)
    Recorder: <HP DVD Writer 1170d> Version: DH22 - HA 1 TA 0 - 7.8.5.0
    Adapter driver: <USB 1.0> HA 1
    Drive buffer : 2048kB
    Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
    Connected to MMC as unknown drive with class-nr : 1
    Drive is autodetected - recorder class: Std. MMC recorder
    CD-ROM: <HP DVD Writer 1170d>Version: DH22 - HA 1 TA 0 - 7.8.5.0
    === Scsi-Device-Map ===
    === CDRom-Device-Map ===
    HP DVD Writer 1170d D: CDRom0
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    BUFE : 0
    Physical memory : 2045MB (2094540kB)
    Free physical memory: 907MB (929544kB)
    Memory in use : 55 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    15.12.2010
    UDF/ISO compilation
    5:53:16 AM #1 Text 0 File SCSIPTICommands.cpp, Line 411
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    5:53:16 AM #2 Phase 112 File dlgbrnst.cpp, Line 1762
    DVD-Video files reallocation started
    5:53:16 AM #3 Text 0 File DVDVideoCompilation.cpp, Line 616
    Content of VIDEO_TS.IFO has been modified
    5:53:16 AM #4 Text 0 File DVDVideoCompilation.cpp, Line 616
    Content of VIDEO_TS.BUP has been modified
    5:53:16 AM #5 Text 0 File DVDVideoCompilation.cpp, Line 616
    Content of VTS_01_0.IFO has been modified
    5:53:16 AM #6 Text 0 File DVDVideoCompilation.cpp, Line 616
    Content of VTS_01_0.BUP has been modified
    5:53:16 AM #7 Phase 113 File dlgbrnst.cpp, Line 1762
    DVD-Video files reallocation completed
    5:53:16 AM #8 Text 0 File Isodoc.cpp, Line 6608
    UDF document burn settings
    Determine maximum speed : FALSE
    Simulate : FALSE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    UDF Mode : UDF/ISO bridge
    UDF Options : automatic
    UDF Revision : 1.02
    UDF Partition Type : physical
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : FALSE
    Allow pathdepth more than 8 directories : FALSE
    Allow more than 255 characters in path : FALSE
    Write ISO9660 ;1 file extensions : TRUE
    5:53:16 AM #9 Phase 111 File dlgbrnst.cpp, Line 1762
    DVD-Video files sorted
    5:53:16 AM #10 ISO9660GEN -11 File Geniso.cpp, Line 3343
    First writeable address = 0 (0x00000000)
    5:53:16 AM #11 ISO9660GEN -11 File Geniso.cpp, Line 3343
    5:53:16 AM #12 Text 0 File Burncd.cpp, Line 3499
    Turn on Disc-At-Once, using DVD media
    5:53:18 AM #13 Text 0 File DlgWaitCD.cpp, Line 307
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 1810127 (402:15.02, 3535MB)
    5:53:18 AM #14 Text 0 File DlgWaitCD.cpp, Line 319
    Write in overburning mode: NO (enabled: CD)
    5:53:19 AM #15 Text 0 File DlgWaitCD.cpp, Line 2949
    Recorder: HP DVD Writer 1170d, Media type: DVD-R
    Disc Manufacturer: CMC MA - G. AM3
    Disc Application Code: 64, Disc Physical Code: 193
    5:53:19 AM #16 Text 0 File DlgWaitCD.cpp, Line 493
    >>> Protocol of DlgWaitCD activities: <<<
    5:53:19 AM #17 Text 0 File ThreadedTransferInterface.cpp, Line 793
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 1810128 (1810128) = #1810128/402:15.3
    relocatable, disc pos for caching/writing not required/ required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1810128 blocks [D: HP DVD Writer 1170d]
    5:53:19 AM #18 Text 0 File ThreadedTransferInterface.cpp, Line 995
    Prepare [D: HP DVD Writer 1170d] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1: Idx 0 Idx 1 Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3707142144, ISRC ""
    DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
    0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 1 | 0x41 | 1810128 | 0 | 0x00
    1810128 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    5:53:19 AM #19 Text 0 File SCSIPTICommands.cpp, Line 209
    SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
    5:53:19 AM #20 Text 0 File Burncd.cpp, Line 4278
    Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
    5:53:19 AM #21 Phase 24 File dlgbrnst.cpp, Line 1762
    Caching of files started
    5:53:19 AM #22 Text 0 File Burncd.cpp, Line 4397
    Cache writing successful.
    5:53:19 AM #23 Phase 25 File dlgbrnst.cpp, Line 1762
    Caching of files completed
    5:53:19 AM #24 Phase 36 File dlgbrnst.cpp, Line 1762
    Burn process started at 8x (11,080 KB/s)
    5:53:20 AM #25 Text 0 File ThreadedTransferInterface.cpp, Line 2721
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    5:53:20 AM #26 Text 0 File DVDR.cpp, Line 3192
    Recording mode: Sequential Recording Mode
    5:53:21 AM #27 Text 0 File DVDR.cpp, Line 3348
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    5:53:21 AM #28 SPTI -1066 File SCSIPassThrough.cpp, Line 179
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x24
    Sense Qual: 0x00
    CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
    Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
    Buffer x0b7662c0: Len x648
    5:53:21 AM #29 Text 0 File Cdrdrv.cpp, Line 9859
    ---- Disc Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
    Data in Burst Cutting Area (BCA) does not exist
    Revision number of maximum recording speed: -
    Revision number of minimum recording speed: -
    Revision number table of recording speed: - - - - - - -
    Class: 0
    Start sector number of the current Border-Out: 0 h
    Start sector number of the next Border-In: 0 h
    Media Specific [16..63]:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    5:53:21 AM #30 Text 0 File ThreadedTransfer.cpp, Line 269
    Pipe memory size 83836800
    5:53:33 AM #31 Text 0 File Cdrdrv.cpp, Line 1338
    05:53:33.783 - D: HP DVD Writer 1170d : Queue again later
    5:53:34 AM #32 Text 0 File Cdrdrv.cpp, Line 1338
    05:53:34.235 - D: HP DVD Writer 1170d : Queue again later
    5:53:34 AM #33 Text 0 File Cdrdrv.cpp, Line 1338
    05:53:34.922 - D: HP DVD Writer 1170d : Queue again later
    5:53:35 AM #34 Text 0 File Cdrdrv.cpp, Line 1338
    05:53:35.655 - D: HP DVD Writer 1170d : Queue again later
    6:03:43 AM #35 SPTI -600 File SCSIPassThrough.cpp, Line 179
    CdRom0: SCSIStatus(x00) WinError(121) NeroError(-600)
    Sense Key: 0x00 (KEY_NO_SENSE)
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x2A 00 00 00 01 A0 00 00 20 00 00 00
    Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
    Buffer x19170380: Len x10000
    0x00 00 01 BA 44 00 07 B7 C5 2D 01 89 C3 F8 00 00
    0x01 BD 07 EC 81 80 0A 21 00 01 EF 31 FF FF FF FF
    0xFF A0 07 00 4C 0C 01 80 00 05 00 3F 00 0E 00 48
    6:03:43 AM #36 CDR -600 File Writer.cpp, Line 303
    Device not available
    6:03:44 AM #37 Text 0 File DVDR.cpp, Line 3750
    EndDAO: Last written address was 415 (19Fh)
    6:03:44 AM #38 Phase 38 File dlgbrnst.cpp, Line 1762
    Burn process failed at 8x (11,080 KB/s)
    6:03:44 AM #39 Text 0 File SCSIPTICommands.cpp, Line 254
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    6:03:49 AM #40 Text 0 File Cdrdrv.cpp, Line 11214
    DriveLocker: UnLockVolume completed
    6:03:49 AM #41 Text 0 File SCSIPTICommands.cpp, Line 411
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
  2. That's a USB drive so the IDE/ATA DMA settings don't apply. The USB port dropping from USB 2.0 to 1.1 speed would explain your problem. Are you using a hub? If so, try connecting the drive directly to the computer instead.
  3. thanks, appreciate the reply.I am connected to comp not using a hub
  4. Member classfour's Avatar
    The Heartland, United States
    I recommend Imgburn for burning - Nero can get a little strange at times.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  5. Ive tried various programs inc img burn not just nero ,all the same results thanks
  6. If the drive is dropping from USB 2.0 to 1.1 frequentsly I would try a different cable.
  7. you mean the cable between burner and comp right?sorry for my ignorance
    thanks
  8. Originally Posted by jfrenchu View Post
    Yes. I don't think it's a likely source of the problem but it's worth a shot. You may need to uninstall the USB drivers and reboot for the driver to revert to USB 2.0.
  9. I tried a diff cable w/o luck .when u say unistall usb drivers,thats just the ones that say usb human interface or the whole lot that say HID compliant device?appreciate your help
  10. no luck therebut I just uninstalled the 3 usb drivers,worth a try,still thinking it could be the burner its had alot of use and it does seem to make a bit more noise these days
  11. Originally Posted by jfrenchu View Post
    Everything under "Universal Serial Bus Controllers".
  12. I tried that but it knocks the mouse out thanks
  13. Originally Posted by jfrenchu View Post
    And when you reboot the USB drivers will be reinstalled and your mouse will work again.
    On some old motherboards pairs of USB ports switched together. So if you have a 1.1 peripheral in one one port the other is forced to 1.1 too.
  14. what I meant was I deleted the 1st driver then the mouse wouldn't work and I couldn't delete the rest.can u dl the whole group st once somehow thanks
  15. Member classfour's Avatar
    jfrenchu - you may be onto something.
    If you have another external writer, have you tried writing with it?
    If you google that model of HP, you are not alone.
    I have a friend who goes through external drives - I just rebuilt a Plextor 716UF that died.
    I had to stick a 712 drive in the thing - but it'll burn 12X (as a 712 should) in the 716 house.
    I tend to upgrade drives on a regular basis, and have had no failures from use (some DOA); but if they're rated for 10,000 cycles - they die.
  16. I don't have another external, was going to try and take this one to another comp and see what happens.I posted this a month ago somewhere with no replies .here I got a bunch in one night.not resolved yet but some helpful folks .thanks
