all of a sudden, nero 8 not burning dvds i'm authoring.... im trying to write to C drive first and then burn from there...
what is wrong?? happens repeatedly very early in the process, just 5 seconds in.... anyone know what this log is telling me?
here is end segments of the log....
[00:09:22] NeroVision Windows XP 5.1
[00:09:22] NeroVision IA32
[00:09:22] NeroVision WinAspi: -
[00:09:22] NeroVision NT-SPTI used
[00:09:22] NeroVision Nero API version: 8.3.2.1
[00:09:22] NeroVision Using interface version: 8.0.1.1
[00:09:22] NeroVision Installed in: C:\Program Files\Nero\Nero8\Nero Burning Rom\
[00:09:22] NeroVision Application: Nero\NeroVision
[00:09:22] NeroVision Internal Version: 8, 3, 2, 1
[00:09:22] NeroVision === Scsi-Device-Map ===
[00:09:22] NeroVision CdRomPeripheral : TSSTcorp CD/DVDW TS-H552L atapi Port 2 ID 0 DMA: Off
[00:09:22] NeroVision DiskPeripheral : SAMSUNG SP1604N/R atapi Port 3 ID 0 DMA: On
[00:09:22] NeroVision === CDRom-Device-Map ===
[00:09:22] NeroVision TSSTcorp CD/DVDW TS-H552L E: CdRom0
[00:09:22] NeroVision =======================
[00:09:22] NeroVision AutoRun : 1
[00:09:22] NeroVision Excluded drive IDs:
[00:09:22] NeroVision WriteBufferSize: 83886080 (0) Byte
[00:09:22] NeroVision BUFE : 0
[00:09:22] NeroVision Physical memory : 958MB (981480kB)
[00:09:22] NeroVision Free physical memory: 400MB (410484kB)
[00:09:22] NeroVision Memory in use : 58 %
[00:09:22] NeroVision Uncached PFiles: 0x0
[00:09:22] NeroVision Use Inquiry : 1
[00:09:22] NeroVision Global Bus Type: default (0)
[00:09:22] NeroVision Check supported media : Disabled (0)
[00:09:22] NeroVision 16.12.2010
[00:09:22] NeroVision NeroAPI
[00:09:22] NeroVision Existing drivers:
[00:09:22] NeroVision Registry Keys:
[00:09:22] NeroVision HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
[00:09:22] ExpressUI Burn process failed with status 3
[00:09:25] AMCUIBase Setting 'ENU' as Nero File Dialog language
thanks for your advice, I realize nero has it's issues. It's the only authoring program I have and that has worked very well with my PC. i have been using this same nero program to create the same type of dvd projects for about 3 months and no problems like this. The only problem with the program you refer is that, I need a program that will allow me to author the dvd also, it's a combination of various sources of video, custom title screens, etc.
I will check into ImgBurn for other applications. It is not going to let me burn the projects I have created in Nero 8 is it?
Right now, anyone who is familliar with the Nero problem, please advse. I have 2 projects saved that I just recently finished... that took me hours to have ready to burn to computer and then hopefully to DVD-R. -
Pardon my ignorance but I'm not sure how to save the created dvd plan to HDD other than what i'm trying to do with Nero, I write it to C drive direct. However, I know it offers to save the creation also as Image... I will try that after work, and then try ImgBurn. Am I on the right track? thanks so much for your inputs!
Question about new type of Nero 6 burn error
By jimdagys in forum DVD RippingReplies: 13Last Post: 29th Jun 2009, 01:22 -
Get a log error trying to convert to dvd disc on Nero 7. Please help !
By seagulls in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2009, 17:00 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
Help. Nero error log
By R!ffraff in forum Newbie / General discussionsReplies: 7Last Post: 3rd Mar 2008, 16:22 -
The last Mimzy wont burn i get this error log???
By joesgotflow in forum DVD RippingReplies: 2Last Post: 15th Jul 2007, 21:37
