I'd like to start adding trailers to my media browser. For older movies, it's hard to locate HD trailers online. Figured I could just grab what's on the disc if it's available but not sure if there is a quick way of doing this
1) Scan the folder with BDinfo. (You can also do this direct from disc with AnyDVDHD running).
2) Note the streams that are likely to be what you want by run time. Verify by playing the *.m2ts file in MPCHC. Jot down the *.mpls file number.
3) Load the associated *.mpls (playlist file) in BDRB using Mode -> Other Movie-Only Playlist.
4) Output as you like. You can use Alternate Movie-Only Output to save to, for example, an MKV.
Good luck.Pull! Bang! Darn! -
The problem is that I still have to go through the files to find out which is the trailer. I'm going to assume there is no app that will pinpoint the right one
BluRays not playing right on N1
By x22 in forum Blu-ray RippingReplies: 4Last Post: 16th Oct 2011, 15:43 -
Few n00b questions regarding backing up blurays ..
By ahmadka in forum Blu-ray RippingReplies: 0Last Post: 20th Apr 2011, 12:49 -
What do you use to play Blurays?
By Dexx in forum Software PlayingReplies: 9Last Post: 24th Jan 2011, 17:27 -
ps3 media server and blurays *wired connection
By krohm in forum Media Center PC / MediaCentersReplies: 4Last Post: 26th May 2010, 20:18 -
Looking for an app that will backup HDDVDs or Blurays with minimal effort
By AndyD in forum Blu-ray RippingReplies: 24Last Post: 5th Dec 2009, 13:48
