I have a digital camera, Fuji finepix HS10. It records HD videos, the resulting file is a *mov file. I also have a Panasonic HD tv - TX-P37X20 - with the "Viera" function, should be able to playback the videos when converted to either Mpeg2 or Avchd format, and transferred to a SDhc card.
Done that - but no luck so far. The message on screen says "No valid file to playback"...I would like to add, that all PHOTOS (*jpg format) comes up nicely as supposed to).
I have tried a couple of different conversion softwares, but same result. Perhaps someone here knows what to do about this, or knows the right software to use for the conversion? Panasonic support talked about some different mpeg2 files, some with "ps", some with ""mod" endings (..??), not sure what they talked about, or how I manage to convert to exactly that kind of format - whatever is is..?
Results 1 to 9 of 9
Thanks -
Ps. -
The HS10 has HDMI out, so you should be able to play video directly to the HDTV without any conversion or transfer.
The MOV file is likely H.264/AVC, which could be turned into a AVCHD structure with an app like tsMuxeR.
Some cameras that record in mpeg-2 save as .mod files (JVC, Panasonic, Canon).
"PS" with regard to mpeg-2 usually means "program stream", that is the way to save mpeg-2 content as a computer file for local playback (usually .mpg), in contrast with "transport stream" which is a specification intended for broadcast/streaming (.ts). -
Possibly ClipWrap.
I believe it has a free trial.HTML Code:http://www.divergentmedia.com/clipwrap
Thanks - yes I know I should be able to play them off directly from the camera - however, the card has been formatted since, after I copied them to my computer, and now the camera cannot see them, although I put them back, in *mov format, to the same folder, where they originally was created?
Why not?
I will try the suggested software also.Thanks -
Ps. -
I believe there are (were) invisible files that are (were) required in order for the camera to "process", so to speak, the video for playback. This is a known issue with many cameras (and camcorders). If ClipWrap doesn't do the job, see if VLC can play the file. If it can, then use VLC's export feature to get the file into a format that QuickTime -can- understand. Keep lots of tools in your toolbox. Please let us know what happens. Good luck!
Downloaded CLipwrap....but hey, is it MAC only? I do not seem to be able to install on my pc...?!
Thanks -
Ps. -
So sorry - I had no idea this is a MAC forum..I rest my case and try another place.
Thanks -
Ps.
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
Mov conversion help?
By Timbo78 in forum Video ConversionReplies: 2Last Post: 13th Sep 2010, 06:10 -
Expert Video conversion help please! .mov to .flv
By KMartin in forum Video ConversionReplies: 26Last Post: 31st Aug 2010, 13:28 -
Expert Advice Needed: VHS Conversion
By Maxac in forum Capturing and VCRReplies: 6Last Post: 17th Feb 2009, 13:33 -
.mov to DV conversion
By aaron_rip in forum ffmpegX general discussionReplies: 4Last Post: 3rd Jul 2007, 16:55
