Hi, i have a ip camera that i want to put in my website. There is some problems concerning the ISP. i dont have a real ip address, and they blocked port 80, and i cannot view the ip camera over the internet. I though about using streaming to upload the video from the camera directly to the web server that is hosting my website. but i need some help on how to do it and how to embed it in my website. Thanks in advance.
Results 1 to 18 of 18
Use something like www.ustream.com and you can embed it on your site.
I don't think that will work. His ISP has blocked outbound port 80 (HTTP) and his IP camera outputs on port 80.
My guess is the camera is normally accessed via a web page. If you look at the code for that page (eg, View -> Page Source) you should see the mechanism that's used to display the video from the camera. It might be as simple as copying that code to your web site. I would also check to see if the camera already supports a different port number. And be sure to set up port forwarding on your router.
http://www.networkwebcams.com/ip-camera-learning-center/2010/02/16/howto-ip-camera-remote-access/Last edited by jagabo; 15th Dec 2010 at 10:51.
Thanks, but even the code in the camera's webpage requires the ip address of the camera or ipaddress and port number, and the problem is
that i dont have and real ip address. If anyone knows how to solve this problem without depending on a real ip address and port forwording i
would really appretiate it. Thanks in advance. -
You will have to use port forwarding in your router under any circumstance -- LAN addresses aren't made available on the WAN. Say your IP camera is at 192.168.1.111 on the LAN, the video stream is accessed via port 5555, and your router's IP address is 123.45.67.89. You set the router to forward all port 5555 requests to 192.168.1.111. Then at your web page you change the code to get the video from 123.45.67.89:5555 instead of 192.168.1.111:5555.
If your ISP doesn't give you a static IP address you'll have to update the web page every time your IP address changes. -
The problem is not that i dont have a static ip address on the router or i would have solved it with DDNS but the problem is that the router have a virtual ip address, which means it cannot be used on the internet. it is not a real ip address.
Virtual ip address on the internet is something used to connect all computers in the LAN using only one ip address and ports to determine the computer in the LAN when receiving from outside. which means all the computers in the network are shown on the internet with the same ip address. that means that you cannot reach the internal computers with the ip address. i know these stuff because i'm a fresh graduate but i dont have experience with ip cameras or video streaming. thanks
That's called NAT -- network address translation. And port forwarding is the way that is handled at the router -- exactly what I describe earlier.
The way I understand virtual IP address is the opposite of what you are describing. It's making several WAN IP address map to one LAN IP address. I don't see how that applies to your situation.Last edited by jagabo; 23rd Dec 2010 at 17:25.
I think what he's saying is that his router is not getting an external IP address from his ISP. I've seen that a lot on residential accounts.
Buy My Books -
So his router is acting as a hub or switch, and each computer on his LAN gets an WAN IP address, not a LAN address? I would get a standalone router and put all the computers and camera behind that. That also acts as a firewall between the LAN and WAN so it's much safer. The down side is that he might get reduced throughput with only a single WAN connection.
No, that's not what I'm saying. Ignore his use of the term VirtualIP, (my understanding of that term is the same as yours). I'm saying that he may be getting something in the 192.168 range, (possibly with a very narrow subnet mask), from his ISP. So from the internet's perspective he has an internal IP address on the WAN side of his router, so it can't be reached. The ISP then shares a single external IP address across several customers. You can probably get an external address from the ISP, but it usually costs more.
Buy My Books -
About what gadgetguy said, i dont really know how it works but its not NAT. I might have explained it in a wrong way but it is still the fact that it cannot be reached from outside. and what gadgetguy said about getting an external ip address, i can get one but it costs alot and i cannot get one for sure, since they only give it for certain purposes.
Without an external IP address and port forwarding WAN clients can't request connections to the computers on your LAN. You'll need to find an application to run on your server and LAN computer that supports client side push. The client (your local computer) requests a service port on the server then pushes the video to the server via that port. The server then serves that video to other clients.
Thanks but i need to stream directly from the ip camera or i would have used a web cam instead. i dont want to use any other computer in the streaming process between the ip camera and the server. i guess there is no other way but to request a real ip address from my ISP.
CamStreamer connects your Axis IP camera to YouTube or other RTMP streaming services. Everything is running inside the camera. No need for computer or public IP address. The camera initiates TCP/RTMP connection to YouTube servers. See http://camstreamer.com
In my opinion blocking ports by ISPs (except for things like Dos protection) should be made illegal by extending the "Network Neutrality and Internet Censorship" initiative.
But are you sure the ISP actually blocks the port, e.g. did you have it confirmed?
Not having a fixed ip address can be (partly) circumvented by using dynamic IP.
ISP problem - some website pages load, other website pages don't
By PartingShot in forum ComputerReplies: 15Last Post: 6th Sep 2012, 23:42 -
DV camera maintenance? (also evaluate my camera)
By CursedLemon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Jul 2010, 08:28 -
SD Video Camera Vs. HD Movie Mode on Digital Still Camera.
By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 14:57 -
What is the best website/ forum for Q's about the model camera I need?
By tenderloin in forum Newbie / General discussionsReplies: 6Last Post: 2nd Sep 2009, 19:32 -
Using a DV camera to import tapes from another DV camera to desktop
By bge20 in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2008, 18:03
