  1. AccountKiller
    Nov 2010
    AccountKiller
    AccountKiller
    Or you could just refer to this: http://www.digitalFAQ.com/reviews/dvd-media.htm
    It already has the most common information anybody really needs to know for buying good blank DVDs.
    Maybe not a need to reinvent the wheel here. Already done!
  3. The last pack I bought of Verbatim few months ago is CMC MAG. AM3.10 bad CD's so far. Buy Taiyo Yuden it's the last good company left
    Nov 2003
    West Texas
    Buying Verbatim these days you need to check the label and look for the AZO designation. The CMC made "Life Series" from Verbatim are ones to avoid.
  5. AccountKiller
    Nov 2010
    AccountKiller
    AccountKiller
  6. Banned
    Freedonia
    I'm guessing you bought the "Life" series which we've talked about quite a bit around here as being inferior. I long ago stopped buying Verbatim in stores and only mail order them because that way I can be absolutely 100% sure I am getting exactly what I want. I buy the DataLifePlus Verbatim discs all the time and their single layer ones are still good old MCC Made in Taiwan discs.
  7. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    You must not have been paying attention to all the threads concerning this,
    https://forum.videohelp.com/threads/320968-So-what-brand-pf-DVD-blanks-is-everyone-usin...=1#post1987426
    https://forum.videohelp.com/threads/319565-Verbatim-Life-Series-DataLifePlus?highlight=verbatim
    Those were the only CMC MAG Verbatims i have personally found.
