I'm fumbling around with my first attempts to use MediaCoder to convert .mkv to .mpg for standard dvd burning. I can't register on the MediaCoder forum to ask there due to the "illegible captcha' barrier".
After a few attempts I've managed to output an .mpg with a fair video bit rate. But it never contains any audio. The transcode gets to 100% then says there's an error. So I have to manually demux the audio from the .mkv and mux it into the .mpg then author. Which kills most of the speed advantage of CUDA.
I'm hoping I can at least get one working profile to take 16x9 mkv and perhaps m2ts and output a dvd5. The throughput is good with CUDA and the video output doesn't look bad. I just want to get away from doing all these manual steps.
Anyone know the trick to MediaCoder settings? I have audio, 448 kbit ac3, enabled and set to Copy. But it never copies.
Results 1 to 1 of 1
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
Re-encode audio but keep video the same in MKV file
By V879 in forum Video ConversionReplies: 3Last Post: 15th Apr 2012, 08:51 -
Can't stream copy H.264/AC3 in .m2ts to .avi with Mediacoder. Suggestions?
By sincostan45 in forum Video ConversionReplies: 2Last Post: 19th Feb 2011, 18:42 -
About MKV To AVI using Mediacoder
By afcoff in forum Video ConversionReplies: 2Last Post: 19th Jan 2009, 04:42 -
MediaCoder - RMVB 2 AVI, video $ audio not synced!
By kehn in forum Newbie / General discussionsReplies: 3Last Post: 6th Apr 2008, 04:34 -
MPG to h264 w/ATi TransCode Converter 1.01b, audio just won't encode *argh*
By ultradouche in forum Newbie / General discussionsReplies: 2Last Post: 26th Nov 2007, 10:33
