hi, guys, I have a lots of pictures of my familys, and because the Christmas is coming, so I would like to make a slideshow dvd from those pictures, so how to do that? Will the windows movie make work for that? or the power point...thanks advance...
Results 1 to 12 of 12
If you want the slideshow to play automatically in a DVD player with music and transitions, the best free program to use is DVD Slideshow GUI, as Baldrick suggested. However, the slides will be limited to DVD resolution 720x480.
If you want a slide show with no music and no transitions, viewable only using a computer for playback, you can prepare the slideshow with Power Point. The advantage is the slides can be in higher resolution.
My brother-in-law sent me such a Power Point slide show, but for my parents to watch the slideshow using a DVD player and their HDTV, I had to extract the slides in .jpg format, name them something like Slide01.jpg, Slide02.jpg, etc. and copy them to a CD. The slides could be advanced manually with the DVD player remote. This will work for many DVD players, though possibly not all. -
The Power Point file sent to me used a .ppt extension, and I have never heard of a DVD player that can read one. Newer versions of Power Point can also produce a multimedia slide show with a .pps extension, but I haven't heard of a DVD player that can play those either. As far as I know watching either type of presentation requires a computer and and appropriate software (Power Point/Power Point Viewer). Doing a Google search revealed there are Power Point to DVD video converters around, but I have no idea if any are worthwhile products.
If your dvd player supports Kodak cd then you can burn them as jpg to cd ... if you want them in a specific order they'll need to renamed ... your dvd player's user manual may include some information on this and the naming / folder structure requirements.
As far as dvd goes the resolution is restricted ... 720x576 (pal) ... 720x480 (nstc) ... DVD slideshow GUI will do the basics (organize, transitions, ect) -
If you want to convert Power Point presentation to a DVD - DVD slideshow GUI can do that too:
MemoriesOnTV v4 works very well.
I've even used it for a few pro projects, when I didn't want to use Premiere.
http://www.codejam.com/slideshow/index.htm
I would not use Powerpoint. WMM is also a crappy choice here.Want my help? Ask here! (not via PM!)
I think what he means that, he wanted to view those pics in DVD format.
DVD like Tranformers have pics viewers and you can use your remote to change the next picture.
Well, I like to do that but with an audio.Do you know why people mostly use Mac in their office?
Because a lot of stress can lead people to jump off the "Windows".
Guys, How can I work with TS files? (Picture inside)
By AsemPlus in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2012, 06:49 -
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 20:42 -
How do you guys convert mpeg-4 file into dvd?
By tendra in forum Video ConversionReplies: 3Last Post: 31st Aug 2010, 02:34 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00 -
How do you guys transfer vhs movies to dvd?
By mmmipa in forum Newbie / General discussionsReplies: 5Last Post: 15th Mar 2008, 17:34
