    Dec 2010
    Toronto, Ontario, Canada.,kjuh9
    I just started to download movies and burn them to dvd......most go well then sometimes when i check to see if it recorded....theirs video but no sound......or it will say it needs to be recoded when i start the burn process. Im not sure if its the disc( im currently using dvd+R), or if its the actual torrent im downloading cause when you search a movie, so many tittles come up and I'm not sure if im downloading the right ones with the system i have.....hopefully someone can help!!!
    Convert and burn with DVD Flick or AVStoDVD or ConvertXtodvd.
    Dec 2010
    I tried dvd flick but for some reason i cant get it to do it from my d drive where theirs more memory.....its wanting to do it from my c drive....any help there......thanks so much
    Dec 2010
    and ty Soixante
  5. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    https://forum.videohelp.com/threads/329439-DVD-Flick?p=2040532&viewfull=1#post2040532
    And that is not a burning issue but rather a conversion issue.
