I just decided to burn a dvd to vcd so I got sefbys manual of this site followed all the instructions till it said click the start button. The start button has not appeared. Does anyone have any ideas?
Is ur player found? Supported?
is your ASPI layer good?
Is there a DVD in the drive?
Are you missing a setting? -
this sounds silly but do you have enough hd space to rip the movie? when i try to rip a movie and i dont have enough space theres no start button.
the start button only appears after you have selected a set of vobs for smartripper to rip....if you choose "movie mode" then smartripper will automatically select the vobs to rip (99% of the time the vobs automatically selected is the movie files)
so if you are using "movie mode" you don't need to manually select the vob files to rip, smartripper should automatically do that.....once the vobs are selected, the start button will appear -
Surpisingly it turned out ot be hard disk space. Thanks for your help. My Vcd works fine :)
The Start button and the Windows taskbar don't appear on both display
By 1234567 in forum DVB / IPTVReplies: 12Last Post: 2nd Sep 2010, 10:39 -
VOB2MPG PRO 3.0.0122 No Audio and No Active Start Button
By MrZ in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 5th Dec 2009, 07:50 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 16:48 -
AutoGK "start" button is greyed out
By Purno in forum Newbie / General discussionsReplies: 3Last Post: 1st Mar 2008, 04:36 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 01:15
