How do I convert MP4 to AVI?
I've been download Lecture series from YouTube, @780p quality.
Here are the complete media details: http://pastebin.com/TAKht9dt
My reasoning for converting MP4 to AVI is for playback on my DVD Player [DivX Supported].
I am currently using DivX Converter to achieve this, however the conversion from input [MP4, 836MB] to the output [AVI, 382MB] leaves much to be wanted.
The output resolution is 720x405, my TV is PAL. The converted video plays perfectly.
Which method provides the highest-quality converted AVI from the YouTube videos [MP4]?
Please tell me which method you would use.
supe
Do what you're doing, just use a higher bitrate (larger file size). Your Divx/DVD player will not play files larger than 720x576 so you won't be able to convert to a high def AVI.
If Divx Converter will allow you to change the frame size, I highly recommend using 720x400 or 720x404 instead of 720x405. Many players will choke on the latter. You can get a little higher quality by encoding at 720x480 with 16:9 DAR flags -- if your player supports DAR flags.Last edited by jagabo; 14th Dec 2010 at 07:54.
Convert MP4 to AVI?
By JS12 in forum EditingReplies: 0Last Post: 22nd Jan 2011, 09:58 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
Best software to convert VOB to mp4 or AVI, or AVI to MP4?
By 80zforever in forum DVD RippingReplies: 7Last Post: 18th May 2010, 13:32 -
Convert DV-AVI to WMV or MP4
By Black in forum Video ConversionReplies: 5Last Post: 24th Mar 2010, 14:08 -
how to convert FROM MP4 to avi etc.?
By neutrino78x in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2007, 06:09
